Question about Ricoh Office Equipment & Supplies
Getting a 33696 error with a ricoh aficio is330dc scanner
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
Posted on Feb 08, 2008
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
SOURCE: I have a Ricoh IS330DC
I had the same problem, resolved as follows.
In the scanner panel, you set NETWORK BOOT = NONE
Antonio :)
Posted on May 06, 2009
Matt_Sr
  • 31 Answers
SOURCE: ERROR CODE SC997 COMING UP
SC997 is an application error that seems to like to show itself on occasion, it's not considered serious. It tends to show up when scanning, and it basically means the copier couldn't do what you just asked it too. A hard power cycle clears it and in many cases it doesn't come back. I would ask your tech the next time he's out to update the firmware. The problem with that though is that your particular model uses the older flash cards to flash firmware and most techs don't have them or know how to use them.
Posted on Jun 18, 2009
  • 39 Answers
SOURCE: I need manual for: Ricoh Aficio IS330DC 11x17 Duplex Flatbed Color Scanner
Click here to Download the manual
Posted on Jun 12, 2012
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
I Want Ricoh Aficio SP1000SF dirver for Windows 8 (64 bit)
Download the software here...
http://support.ricoh.com/bb/pub_e/dr_ut_e/0001246/0001246934/V204j/z60275L12.exe
After extracting the files and getting the error message that you OS is not supported, browse to the Companion Pro LL V2_0_4 folder and open the Companion folder. Double click setup, and only install the Printer and scanner drivers when prompted. The default location that the software is saved to is listed below...
C:\Users\"your user name"\AppData\Local\Temp\Companion Pro LL V2_0_4\Companion
Jul 28, 2014 | Ricoh Aficio SP1000SF Multifunction...
Ricoh Aficio Sc 122
The scanner home position sensor
does not detect the home position
during initialization.
Causes:
Scanner I/O board or SBU defective
• Scanner motor defective
• Harness between scanner I/O board
and scanner motor disconnected
• Scanner HP sensor defective
• Harness between SBU and HP sensor
disconnected
• Scanner wire, timing belt, pulley, or
carriage defective
Aug 14, 2012 | Ricoh Aficio 2232C Color Copier
Close ADF cover 4732 on a Ricoh IS330DC. How do I fix this.
I'm not familiar with this model, but if it says to close df cover, then either the cover is not closing all the way, a plastic piece on the inside of the cover that actuates the switch or sensor is broken or the switch itself is out of position, dirty or broken. Good luck Colin
Jun 28, 2009 | Ricoh Aficio 1013F Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Aug 08, 2007 | Ricoh IS 330DC Flatbed Scanner
1,169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
