Question about Ruud Handler Air Conditioner
Air conditioner unit is working but the inside fan is not cutting on.
  • 674 Answers
Check your circuit breaker for the indoor fan. If that is ok try turning the indoor fan by hand to see if it rotates freely. If it doesn't it probably needs to be replaced. If that's ok then check the capacitor for the indoor fan. It is probably attached to the fan. You can check it with a multimeter with the capacitor check function or take it to a heating and air supply and they can check it. Also check the fan motor windings. Connect one lead of an ohmmeter to the common leg and the other to the start leg. Check the reading remove the lead from the start leg and connect it to the run leg and see what it reads. Common to start should be higher than common to run. If either indicates an open winding then the motor needs to be replace. Some motors have more than one speed. High speed is usually used for A/C.
Posted on Jul 17, 2010
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My carrier air conditioning unit will not cut on, nor will the fan outside on the top of the unit, but the fan inside will.
Check the breaker for 220v or tripped.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | Heating & Cooling
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
Ac works but when cut it off blower comtinues to work inside house-will cut off with the braker switch on it but turn it back on and it comes on even when air is set on off. Please HELPPPPPPPP!
You have a bad fan booard or fan relay. Get service tech to change. Some things you cant do yourself. To many fan boards are out there. Fan relays are pretty common. Goodman units have a fan sequencer. Carrier Brynats and and others have fan boards. get a quote befor you commit. That way you know how much it will cost. Rus
Jun 26, 2009 | Weather King 10AJA3601AH Air Conditioner
Air conditioner not working
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Sep 08, 2008 | Heating & Cooling
Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Oct 10, 2007 | GE AJCH10ACB Built-In Room Air Cool Unit
Heating & Cooling Logo
107 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
