Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
PDP4294 PowerSupply Components
Im looking to buy a replacment Capacitor for my power board. Cap model is SHINSHIN P0.22k400. Does anyone know where to find one.
  • meadcorp Apr 21, 2008
    What would be the uf and Volts on a p0.22k400 orange Drop capacitor? I am assuming It would need a .0022uf at 400VDC.
    It swelled and blew a nice whole through the side.
For the life of me, I can not find those caps online. Anyone have a direct line to the item? Mine also blew out yesterday.
Posted on May 12, 2008
  • 22 Answers
You all are helpful thanks, i just don't have the knowledge to measure voltage, where, how etc.
Posted on May 08, 2008
  • Kris Luettchau
    Kris Luettchau May 14, 2008
    Here it is..!.
    That's funny, the pic above looks exactly like mine.
    I ordered mine from a Arizona company, it was 2.02$,should get here soon.
    T--(Thanks for the how to check the voltage post. these dont go in order back and forth, so sometimes it gets confusing)
  • Kris Luettchau
    http://www.tubesandmore.com/
    Problem Solver:
  • 17 Answers
I repaired my power board today. I replaced the same caps. There's two of them. Mine said Shin Shin P224K 400. Same thing. They are C523 and C524 located between the VS transformer and the two big power transistors. They are both inline before the VS transformer so being damaged, they have lowered the voltage to VS.
After replacing the caps, I got full power back to my PS. The only power that was affected was the VS which is suppose to be around 90v. It was only 68v. My black screen came back on. I think the value of the caps is either .022uf or .0022uf. I'm thinking more the .022uf. I don't think it is even .00022uf mentioned above.
  • Ter Xiong May 09, 2008
    It's very easy to measure the voltage. Sometimes requires a steady hand though. All you need is a multimeter or voltmeter. One can be had at Harbor Freight Tools for $3 which is very cheap for an ok multimeter. I have like three of them. They usually run $20 at normal retail. There is two probes. A black and a red. With the board in the tv and powered on, use the black probe to touch the aluminum backing of the tv set and with the red probe, you can use either of the white connectors at the top sides of your ps board because they have the same pins. They each are labeled like VS for each pin in the connector. Use the red probe to touch that pin. You should get a reading of around 90v. The voltages should be listed on the aluminum backing of the tv screen near the top right on a sticker. If you need the voltages just let me know.
    Scholar:
  • 52 Answers
Any manufactures cap will do, www.jameco.com and www.digikey.com have a great supply of caps. Just make sure that the uf and volts match up and you will be fine.
Posted on Apr 21, 2008
  • Greg Steilen Apr 21, 2008
    You need a poly film ( orange dip) cap.. Digikey has the largest selection.
    http://search.digikey.com/scripts/DkSear...
    Its kind of late and my mind is a little slow, but it should be either the .0022uf or the .00022uf @ 400v. I will post back tommorrow when I think I get my mind back.
    Just curious, did this burn up? or how did you determine it was bad?
  • Greg Steilen Apr 24, 2008
    Yeah, I have only see that happen once, blew a nice puff of smoke as well. Normally they just short out and dont really show a sign unless other than on the meter. Was this right by the ac connection or floating on the hot side of the board.. Must have had a good spike as the cap is 400v.. Depending on its location, it should be sitting at either rough 200v or max 380.
No Power
hiya
if u change the fuse inside the actual sub shud power up ok
Rik
Feb 26, 2009 | Sunfire True Subwoofer Mark IV Subwoofer
HOW TO GET POWERSUPPLY?
We have seen many large flat screen TVs do this. It is usually one or more bad capacitors on the power board.
  • A cap is a few bucks and easy to replace if you can desolder and solder.
  • You need to identify the bad capacitor.
  • The bad cap will look buldged out or extra fat and deformed.
  • The small cross on the top of the cap usually splits when they go bad.
  • (This is because of a chemical reaction in the capacitor that expands therefore leading to the buldging.)
  • Find the bad cap and replace it.
Apr 05, 2016 | Hisense Televison & Video
RCA 37" LCD TV WILL
Nothing lights on the tv at all? Even the LED power indicator? Might have taken a power surge/hit. Chances are it popped a capacitor on the power supply or logic board. Nothing short of a actual electronics or tv repqair shop is going to help you unfortunateley. Unless you know how to look at circuit boards and are comfortable taking apart the tv while unplugged of course) but be careful becase the power supply can still carry a lethal charge on it if you are not careful. If you know somone who knows circuitboards and can solder and unsolder then you might get licky if it's a capacitor or a resistor. If it's a IC chip though you are going to have to buy a board or a powersupply. So again you really need to find a local tv repair shop.
May 16, 2011 | Televison & Video
Will not power up. fuse is good.where can I buy the power supply assembly?
Usually you cannot buy replacement powersupply boards for dvd players unless you buy a scrapper one off an auction site and use that , but before you go out spending any money, check the capacitors on the board which look like little blue cans, see if they have a buldge in the top and if they have then they will need changing. Check for any burnt components too.
jon
Aug 07, 2009 | Toshiba SD-K860 DVD Player
Kenwood chef A701A capacitor and other components.? I thought it would be a good idea to replace the capacitor on my Kenwood Chef A701A because of its age and before it blows!! Can you tell me if the...
The 0.1 microfarad can be safely replaced with a 275 VAC 0.1mF mains capacitor. You can remove the clip that held the old electrolytic capacitor by sliding the old capacitor out and squeeezing the metal clip so that it disengages with the plastic base. The load resistor is 450 Ohm 15W or 20W wirewound. There is a 56 ohm resistor in series with the capacitor which helps smooth the speed change and reduces wear on the contacts. A 2W wirewound resistor works best. (It is worth removing the contacts and removing any pitting or carbon build up with fime emery paper). I have repaired about 20 speed controls sucessfully with these components.
Sep 10, 2008 | Kenwood KM800 Major Classic Stand Mixer
Tiny/Samsung PS42D8 Plasma
I have the same problem with a samsung power board in a hyaundai TV. PSU Model B4K-50.
I think my 2SK2372's shorted due to the faulty orange / red capacitors between the two FETs C523 and C524 which have the markings on them P0.22K400 which I assume are 220nF 400V.
They had basically no storage capacity left in them.
I am about to order the new parts and see if this thing powers up!
These capacitors are SHINSHIN capacitors
Jun 15, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Akai plasma tv 5 blinking red lights PDP4298ED
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
May 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Power supply
Here is my board that i ordered for replacement, as you can see, the top left second in --cap IS BLOWN. so i think i can either, use a cap from my other board into this and see if it works, or.....test out my current board, and use this board for parts.
any suggestions, that be great. As far as,... which diode.. maybe this can help. cheers.-- Goat
Mar 11, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
847 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
