Question about Mitsubishi HC1500 DLP Projector
Hi, My hc1500 Is having a problem. When I turn it on it makes a clicking sound. Then the Lamp fails to light. The Light is green and the status is green, but soon after the projector shuts off the power light is red and the status light is blinking.
  • 22 Answers
The clicking sound is the high voltage power supply trying to
ignite the gas in the lamp. The lamp is not firing and coming on.
Check the bulb/ lamp life. Possible the lamp has exceeded its
useful life and may need to be replaced.
Posted on Jul 21, 2010
  • reetot Feb 15, 2011
    khanhlehuu, I'm curious if this worked for you...we're having the exact same problem, but our current bulb only has 65 hours on it.
Hc1500 projector will not turn on
Sounds like the lamp. The only way to really check it is to either put a new bulb in or put the old bulb in a different projector. Neither of which probably help you at this point. But, it does sound like the lamp is blown.
Mar 30, 2014 | Mitsubishi HC1500 DLP Projector
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No projection
This sounds like the lamp has not fired. Try a new lamp. If that fails to resolve hte problem, the ballast is the next assembly to be replaced.
Dan
May 12, 2008 | NEC HT410 Multimedia Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Mitsubishi HC1500 DLP Projector Logo
699 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
neOen
Level 1 Expert
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
