Question about Philips Magnavox 13MT143S 13" TV
Okay im 12 and my mom blocked every channel above tv-pg i wanna unlock parental control so i can change it but i want the password to stay the same so when she trys and gets on it she wont see that it has been changed
  • Philips Master
  • 8,457 Answers
Not possible,if u able to find out the password take it off.Use it,put it back on.U can't hide the password is off.
Posted on Jul 16, 2010
How do i unlock lost or forgen password.?v hold
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
May 24, 2013 | RCA E13320 13" TV
I have a 32" Dynex
Need the model number to look up the parental control steps. you will need to access the control settings in the Menu, the channels option. the TV will prompt you for a password, if you don't know it, there is always a default you can use listed in the manual. You can turn off Parental controls in here.
May 11, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Forgot my password on my 27
If you forget your password, simultaneously press and hold MENU on the
television and volume down on the remote for 3 seconds. Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls. -(F27442 User Manual pg.38)
Mar 13, 2010 | RCA F27442 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Turning parental control blocks off
Parental locks are put in place to stop minors from accessing usuitable programs. An adult usually selects the channels to lock out as well as categories of videos that can be played. Thesae are controlled by a code neterd by the Parent or Giuardian and cannot be subverted without knowing the code. I am tempted to say.... ask your parents for permission to unlock this. We cannot supply any information without proof of age here.
With this model also there are no secret codes listed to over ride an entered password as its not a regular brand of TV. maybe the people you bought it from ( Walmart?) may be able to contact the supplier who rebadged this unit, to help you overcome the problem
Sorry we cant be of more help for you. Please accept our apologies
Thank you for using FIXYA
Sep 25, 2009 | Prima C2012 TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
The wording "protected program by TV PG" is on my tv and i cannot access any of my tv channels. How do I remove the block?
Access the menu and go to Parental Control. Change the settings to allow the types of programs you want to be unprotected.
Jul 09, 2009 | Televison & Video
Parental control code
ok first go to the DVD setup which should be located near the bottom of the remote is says SETUP. Then it will give you a list of options go to the one with the parental code one. Then you should try and change the password. My tvs old password was 8888 but I am not sure if it is the same on all tv's. If it is right then you should be able to change the password to whatever you want! I hope this helps anyone who sees this response!
Sep 09, 2007 | Aiwa VX-S207 20 in. Combo
Most of the stations are blocked!
Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
Jul 30, 2006 | RCA E13319 13" TV
Philips Magnavox 13MT143S 13" TV Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
