Question about Haier Mechanical Air Conditioner HWF05XC7
Draining there are no holes for the water to drain out so i have to take it out of the window and get me carpet wet why?
  • 456 Answers
Try putting a shim under the front end so it is not level
Posted on Jul 17, 2010
The passenger floor carpet of my 2000 passport is wet but I don't know where the leak could be. nothing else in the cabin is wet, particularly the areas directly above the floor carpet
You did not indicate what sort of climate you live in or exactly where the carpet in the cabin was most wet...
However, the most common source of water inside a car is a clogged HVAC (heating, ventilation, and air conditioning) drain tube. This tube provides drainage for water condensing on the AC evaporator and any water that enters the HVAC system during rain storms. If the tube is clogged with dirt and debris the water drips from underneath the dash where the heat vents are ... onto the floor instead of dripping onto the road. So usually the wettest place on the carpet is the front passenger foot well.
The drain tube is generally located on the firewall, low on the passenger side. You would probably have to raise the car to see/reach it. I am not sure exactly where the Passport one is ... they can be hard to find at times.
Other possible sources of water are a clogged sunroof drain tube, leaking window seals, torn or missing door seals, and clogged door drain holes.
Also ... buildup of debris (pine needles/leaves) where the windshield wipers retract in to can also block those drains which can sometimes cause overflow into the passenger compartment.
After you find and eliminate the source of the water you will have to lift the carpet and remove the padding underneath in order to dry it. The padding holds water like a sponge and will not dry unless it is removed from the vehicle. Shop vacs won't get the water out of the padding. Even if the carpet feels dry the padding underneath may still be wet, and that is where mold and mildew grows.
Helpful?
Good luck on your troubleshooting
Feb 09, 2018 | Honda Passport Cars & Trucks
I have a 1991 chevy lumina euro and recently while raining the passenger side front and rear carpet is getting wet,can't find where the water is coming from. All window seals are fine. Any idea why?
possible that the water is getting into the car from a failed membrane that seals all the openings under the door trim and /or the drain holes at the bottom of the doors are blocked
fix is to clean out the drain holes and remove the door trim and reseal the plastic back around all the openings in the inner door frame
Jan 19, 2017 | Cars & Trucks
Buick passenger side front and rear carpets soaking wet
The two most common causes are rain water leaking in or the ac drain being clogged up. I would vote for rain water if the entire carpet area is wet.
Could be coming in around the windshield, or one of the door gaskets.
Feb 22, 2014 | 1996 Buick Park Avenue
Wet carpet passenger side
DRAIN HOLES IN BOTTOM OF DOORS? UNDER BONNET BELOW WINDSCREEN CAN COLLECT A LOT OF STUFF
Jan 23, 2014 | Jaguar S-Type Cars & Trucks
On my LG window AC Md. LWHD1009R, I cannot find a drain hole to let the water out. The back bottom of the pan was filled water containing a rusty sludge, but the heat exchanger coils are aluminum, so it...
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Apr 24, 2011 | Heating & Cooling
Same problem with 99
Try running a hose on the driver's door window to see if the drain hoeles in the driver's door are plugged. Also check the drain holes in the rear window and trunk lid drains. If one of the drain holes is plugged the water will seek the next easiest way to drain (which might be to the iside of your VW Beetle.
Jun 04, 2009 | 2003 Volkswagen New Beetle Convertible
Floors in passenger and drivers front are wet 2004 cayenne
Your air conditioner water drain holes are blocked. Check the exit holes for water from the evaporator unit under the foot wells or dash unit. Through these holesor unblock these and the water will flow through to the outside
Mar 23, 2009 | 2004 Porsche Cayenne
Carpet wet behind driver seat
look for rust holes, missing drain plugs, in the floor pan, under the car, spray when driving also comes up off the road and tires, there are a number of points of entry, seat mounnts transmission mounts
not really a solution, just something to check
Oct 13, 2008 | 2002 Pontiac Bonneville
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Haier Mechanical Air Conditioner HWF05XC7 Logo
155 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Bonded Repair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
