Question about Moen Posi-Temp Single HandleTub And Shower Faucet
Installed new Moen posi-temp cartridge. Hot & cold water is correct but water will not shut of*** the way.
I just had the same experience, except I used a non-Moen cartridge. (It was from Ace Hardware, and Ace told me that Danco was the manufacturer.) When I pulled the cartridge back out, one of the two hard plastic seals on the side of the cartridge had torn, presumably on the sharp metal opening on the water supply pipe. I'm guessing there's something wrong with one or both of the seals on your new cartridge.
Posted on Jul 22, 2010
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a moen posi-temp shower valve and it says "up" on 1 side. when it is installed this way the hot is on the wrong side. the hot is hooked to the left side but the handle points to the cold...
you need to pull apart the handle and rotate the cartridge 180 and reassemble and that will put the hot on the left and the cold on the right before you put the screws all back in test it to make sure its correct then reassemble IF THIS HELPED YOU PLEASE VOTE FOR ME AND LEAVE GOOD FEEDBACK
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
278 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
