Question about Amana Refrigerators
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be staying frozen, but it takes longer for meats etc to freeze; also it stopped making ice.
  • Amana Master
  • 8,220 Answers
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 16, 2010
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Amana ABB2224DES - 5 years old - freezer is not keeping ice cream frozen it is mushy - the freezer setting has been set on 6 for a long time
Check temp. should be around 0. If not check to make sure condensor fan motor is working. Check condensor for lint. Do not put ice cream in door shelfs this is the warmest point in freezer. if has a icemaker, check to see if ice in bucket has a wet look or dry look. Wet is a not cold enough. dry is cold enough. If refrig is cycling of and on and temp is 0 , ice dry... possible bad thermastate/ sensor.
Mar 05, 2010 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Ice maker quit working and I feel that it is not getting as cold as it should (i.e. ice cream melts but other items like vegetables stay frozen).
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath or low freon from factory or small hole in system
Aug 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
524 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
