Question about Sony Cyber-shot DSC-W80 Digital Camera
I got sand in my camera lens. And now the lens stay closed. The camera works. But the lens just don't open.
  • 3 Answers
Get your fingernail or something sharp and put it between the lense gaps to get the sand out, or try the hover
Posted on Jul 18, 2010
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
Apr 13, 2014 | FUJIFILM FinePix JZ300 Digital Camera
Vg-120 wont open
I know this is just southern inginuity but ours did the same after a trip to the beach. my husband took a knife and removed the outer rim, to loosen the sand out, then we had to tape the ring back on. still works. but if you don't won't to damage your camera, you might not want to do it that way.
Jul 27, 2012 | Olympus Software VG-120 Digital Camera
My nikkon coolpix is a month new and almost only 3 weeks used..my uncle bought it in states...when i am taking pictures i zoom it and a message "LENS ERROR " appear on the screen and because i...
1.Check if something block it (maybe sand or smt like that
2. Never pushed lens manualy (you may broke it completly)
3.Just try to shake or slap it jently while open or close it.
Jun 07, 2011 | Nikon Coolpix S3000 Digital Camera
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom error too
if you spill any thing, like a soft drink,tea,coffee,etc. anywhere around the camera, when the lens barrel is open, it will cause it to stick when it is closed. so when it dries, you are stuck. put fresh batteries in, and with a rubber mallet, lightly tap on the face of the lens, when the camera is powering-up. do not hit it hard. after two taps, my camera lens opened up. you can clean the barrel with some wd-40, with a q-tip swab. use very sparingly. and next time, be very careful where you lay-down your camera. you never know......
Jul 08, 2007 | Fuji FinePix A350 Digital Camera
Canon ixus 55 - stuck in open position after sand intrusion
DON`T OPEN THE COVERS - YOUR SELF!!...You have to use ESD!!! Your cameras optical-unit needs operation. It`s not "self-made"-project!
May 10, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
171 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
