Question about Bosch Freezers
Problems with the temperature dropping quickly
We are constantly defrosting the elements at the top of the freezer which gets the freezer back to 18 degrees then over a couple of weeks or sometimes days it will drop constantly until the alarm comes on.
The freezer has been like this for some time. So much for frost free!
    Guru:
  • 1,524 Answers
Sounds like a refrigerant charge problem.
Posted on Jul 19, 2010
Kenmore elite upright freezer model 25326093100
It does sound like the thermostat is acting up. It could also be a defrost timer if it is a frost free model. The timer could be running slow and remaining in defrost longer than it is designed to. Thermostat can get erretic also and work fine sometimes nad then not work correctly another. When it is shut off after cycling off tap the thermostat. if it comes back on thgis could be your problem.
Apr 03, 2014 | Freezers
When I got home I heard the buzzer going off on the freezer..the temperature had dropped from -12 to -2 and I'm trying to reset it to-12 again how do you do that?
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Jun 29, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Our upright freezer tends to drop water at the back and a build up of ice occurs, any suggestions of what the issue might be
Defrost element inside the freezer faulty,,,Fan unit not operating or defrost timer faulty..
at the very worst, it could be low on gas.
Get back to me if you need to clarify more process of the problem
russ_sheraton@hotmail.com
dont forget to vote....cheers, Russ
Mar 07, 2011 | Danby Upright Freezer EV209NBTQ
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Freezer temp rises to -15 deg. and is slow to return to -18 deg.
Hi, this unit may be going through its defrost cycle when you notice this warming up time. They defrost on time and temperature depending on the model. If it does this constantly, like a lot, you may have a problem some where. Keep an eye on it and try to time it if at all possible to see the duration of this warm up spell. Please keep me posted on this so I can get to the bottom of this.
Sincerely,
Shastalaker7
Mar 17, 2010 | Freezers
The temperature gradually heads towards the + side from an intial -18. It is not overpacked with food and has to be switched off for 24 hours and restarted before the temperature drops again Why?
poss cause machine is in auto defrost mode.check food still at minus 18c or lower.also when was the last time you defrosted/cleaned filters and drain pipes manually?
Feb 04, 2010 | Freezers
Defrost cycle on my elecrtolux ER 7926/1 B fridge freezer seem to be to long and temperature in the freezer drops down to 0 C every defrost cycle, does enyone have a wiring diagram for this model please
No i dont but i could suggest you check the heating element and the clixon that connects to the evaporator. If the heater does not function, it takes a much longer time than usual to switch the freezer on.
Sep 21, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
269 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
