Galaxy Radios DX 77HML Base CB Radio Logo
Posted on Jul 16, 2010
My modulation is very soft and also the low-med-high it dead keys from 2-3
Anonymous
Level 1:
  • Contributor 64 Answers
  • Posted on Sep 12, 2010
Anonymous
Contributor
Level 1:
Answers
64
Questions
0
Helped
16002
Points
77
There is a control inside that limits the modulation it needs to be increased so that you have full modulation likely.
1helpful
I lost their measuring cup is it the same as a one cup measuring cup?
Here are the amounts - in teaspoons of water:
Soft Boiled Eggs
4 tsp 6 soft
5 tsp 5 soft
6 tsp 3 soft
7 tsp 1 soft
Medium Boiled Eggs
7 tsp 7 med
8 tsp 6 med
9 tsp 5 med
10 tsp 3 med
11 tsp 2 med
12 tsp 1 med
Hard Boiled Eggs
14 tsp 7 hard
15 tsp 6 hard
17 tsp 5 hard
18 tsp 4 hard
20 tsp 3 hard
21 tsp 2 hard
23 tsp 1 hard
Ac blower motor stopped working
YJ car.
the blower is dead. is that it?
does it blow full speed on high
do you have 12v on terminal A of blower , term B is 0v ground
got that, then the blower is dead.
if not 12v, then the controls are bad.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
page 47
4 parts to make blow
1: fuse 12 good.
2: switch heater /on off.
3: high, med,low speed, use high, its direct.
4: the blower,
one of those points has no 12v on high,
use a simple voltmeter to find the failed point.
How do I wire blower moter
Black- high speed Red- low speed Blue- med. high Yellow- med. low White- neutral Usually black on "cool" terminal on board, red on "heat" terminal on board, and remaining 2 on the "park" terminals on board. White goes to the neutral terminals. Hope this helps!
Blower MoterElectrialDiagram for a 40,000Furnaces to a Ton1/2 Air conditioner
You will put the red wire from the blower on the terminal marked "heat" on the control board. Black= high speed Red= low speed Yellow/Blue = med low/ med high Hope this helps!
3helpful
Instruction manual is in french ,need it in english
Egg Genie cooks up to 7 eggs at once-with no guesswork, no underdone or overdone eggs.
Just add the indicated amount of water.
Press "on"and your work is done.
The Egg Genie automatically steams eggs and alerts you when they're ready.
Here are the amounts in teaspoons of water:
4 tsp = 6 soft boiled eggs
5 tsp = 5 soft boiled eggs
6 tsp = 3 soft boiled eggs
7 tsp = 1 soft or 7 med
8 tsp = 6 med boiled eggs
9 tsp = 5 med boiled eggs
10 tsp = 3 med boiled eggs
11 tsp = 2 med boiled eggs
12 tsp = 1 med boiled egg
14 tsp = 7 hard boiled eggs
15 tsp = 6 hard boiled eggs
17 tsp = 5 hard boiled eggs
18 tsp = 4 hard boiled eggs
20 tsp = 3 hard boiled eggs
21 tsp = 2 hard boiled eggs
23 tsp = 1 hard boiled egg
2answers
Were is the low speed fan control relay located at
There is not one,it has a blower resister that e\includes the low,med.and if there is one a med-high it is a module,and it has multi wires going to it,and is mounted on the blower box near the blower motor.
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
