Question about Miele Novotronic W1918A Front Load Washer
I have 2001 Miele Novotronic W828 front loading washing machine. The rinse light is flashing. I have turned it off and started again and it still keeps flashing. Can you please tell me if there is something I can do to fix it or do I need a technician. Thank you
  • 10,515 Answers
The rinses light flashing is the error code for a motor circuit fault on most Miele washing machines.
As the motor is running in the wash mode but not in a distribute or spin mode this would suggest a fault with the motor and/or the motor control board.
Miele parts are very expensive so you will have a bill in excess of £200 for a motor or a control board.
I'm sorry to be the bearer of bad news.
If you are thinking of having Miele come in to do the work their labour charge (or call out) is just under the £100 mark.
Unplug the appliance, gain access to the motor and check the wiring to it, check the wiring to the pcb (control board) and check the carbon brushes in the motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 17, 2010
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W1918A Front Load Washer Logo
819 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
