Question about Toshiba 50H82 50" Rear Projection Television
TV picture scrambled and getting worse
I have a toshiba rear projection tv. When I turn it on the screen is completely scrambled and it take a good 10-15 minutes to warm up. Once the picture and sound come on, depending on the channel it may or may not be a good picture. The picture will go all scrambled or the colours get all screwed up. But when I watch a DVD there is no problems ever. What could this be??? Picture tubes or someone said the receiver, or just a really bad cable signal??? Any info would help..
    Genius:
  • Toshiba Master
  • 1,673 Answers
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Posted on Apr 21, 2008
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
it's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Dec 09, 2012 | Toshiba Televison & Video
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Lightning strikes on screen and takes awhile to warm up then fine
sorry its not an easy fix at all. im sorry wat you have to hear, but do you have kids? if so, they probably bumped into or hit the screen. that would result in permantly damaging the screen
Aug 22, 2008 | Toshiba 50H81 50" Rear Projection...
Scrambled picture
I have the same problem here as well, except that it has been happening so long that now it doesn't get completely clear. The picture was great at one time :-(
Jul 07, 2008 | Toshiba 50H81 50" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba 51h83 projection t.v. scrammbled lines across the screen.
I've seen this problem before with Toshiba sets. Normally it's been caused by the hyper module. Usually, the set is worst when first turned on and clears up some, if not completly after it warms up. The problem does get worst over time.
Jan 27, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
231 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
