Question about Honeywell Heating & Cooling
Honeywell CT3200A1001 came with home purchased no user manual - How do I override temperature set on cooling?
Destinova
  • 46 Answers
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
SOURCE: Honeywell K4392v2 M6983 REV Home Alarm
http://www.security.honeywell.com/hsc/resources/literature/index.html
Posted on Aug 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
  • 8 Answers
SOURCE: cooling temperature will not below 70
controllers more than likely on a memory lockout... kill the power and take the batteries out of it... leave it for 60 seconds and try again... unfortunately you are probably going to have to replace the controller, sorry
Posted on Jun 16, 2009
Can I manually override a Honeywell 69-0940-2? I don't want to program it. Just want to turn the air on for a few hours to cool the house. Thanks
That thermostat cannot be overridden to remove the seven day schedule. If you select you desired mode (HEAT or COOL) using the SYSTEM button, then using the UP or DOWN arrows next to the screen to set your desired temperature, finally press the HOLD TEMP button to lock that setting in. It should stay there until you press hold temp again, make a temperature set point adjustment, or a loss of power. These thermostats are kinda complicated for the everyday user and were usually installed in commercial buildings where the end user's access was limited. Hope this helps. I also provided a link to the Honeywell Manual. http://www.transtaracsupply.com/pdf/t8600manuel.pdf
Dec 13, 2017 | Honeywell Heating & Cooling
Temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
Nov 07, 2011 | Honeywell Electronic Programmable...
Directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 17, 2011 | Honeywell Heat/Cool Thermostat
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
I have a Honeywell CT3200A1001 in my home, I need help! It kicks on but won't heat the house passed 71 degrees. The furnace seems fine but the thermostat just keeps turning it on and off with no results...
try replacing the battery in the thermostat i am not familiar with this particular model but had a similar problem in my home replaced battery and now works good
Oct 10, 2009 | Honeywell Electronic Programmable...
Cooling temperature will not below 70
Jun 16, 2009 | Honeywell Programmable Thermostat Heater
Unlock a Honeywell Thermostat
That is correct hold the override button and the + button for a few seconds. Then you will see it flash and you can change the temperature then
May 28, 2009 | Honeywell Electronic Programmable...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
295 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
