Question about Dometic Refrigerators
No power to the unit. I have checked the power source at the back of the unit and I have power there. I replaced the circuit bourd on the back of the unit and still don't have power to the unit inside the RV.
  • 2,005 Answers
If this rv frige is 12 volt check the voltage inverter under the bottom of the frige if it is gas check the electrical heating element at the gas flue befind the frige.
Posted on Jul 16, 2010
Samsung UN40JU6500F had picture on intial power up, changed source and lost picture. Can't get it back, only sound. See faint images. Bottom back shows blue lights on. Inverter? Power board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 26, 2016 | Samsung UN Televison & Video
Samsung TV no picture from any sources.
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 26, 2016 | Samsung Televison & Video
Jandy aquapure 35 i have had mine installed-hard wired, by a pool contractor 4 2 months, and all of a sudden it just died. No power to the control unit. Fuses blown ,new fuses blown as soon as power...
hi
it looks that there is short circuit from the power source to the control unit.
put a temporary supply to the control unit if this works there is a fault from the power source to the control unit.( short circuit power going to earth ) if it the same then there is short circuit from the control unit to the auxiliary
Jul 26, 2013 | Jandy AquaPure Ei Series 35K Salt Water...
Tv went off wont turn back on
Make sure you've unplugged all external connections to unit. Try unplugging TV from power source for no less than 10 minutes. Plug in again, and see if it comes on by depressing the unit's ON/OFF switch (NOT via remote). If not, then try something in receptacle that you're plugging into. If no power, then check your circuit breaker. If still no power, then may require service.
Jan 14, 2013 | Televison & Video
No power to unit
Whether this is a window unit or a built-in unit, check the source of the power. Is there a circuit breaker in your home's circuit breaker panel that has been tripped? If so, it's probably the one that serves the AC unit. Reset the breaker and see if it trips again, after you turn the AC unit ON. If it does, either that circuit is overloaded or there is an electrical short in the AC unit.
Hope his helps you troubleshoot the problem.
Apr 05, 2011 | Heating & Cooling
Sanyo 52 " loud pop,
Sound like you blew a capacitor. Check for any oil on the circuit bourd and check for any bulging capacitors.
Feb 06, 2011 | Televison & Video
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Burn out circuit board
hi! there! replace the burn out circiut board,what ever you pull out the same thing you put back just be sure that has the same model and specification,calibrate and test overload protection,defective overload protection replaced to prevent any burn out,short circuited mostly came to burn those thing that's why imposing preventive maintenace schedule for this kind of large ac central unit is very much significant.mostly timer delay circuit malfunction on large scale unit supplying by three phase a/c source on central control panel board.when ever replacement occured try to put mark or list color coding of specific terminals to connect and isolate short circuit make possible to detect at once before installing the new one and make make record on this for future reference we have several cases like that after buying a new one and replaced still burn again,the common cases is that they did not find the cause of short circuit connection they just relay on circuit board burn out,so it better to make assured that every thing is fine before installing the new one.specially on supply source of circuit.,relay on diagram and manuals take and check all data source as reference this will be a great help.take all necessary precaution this should be done by qualified technical ac support,have a nice day and regards
Mar 31, 2009 | Heating & Cooling
Fan will not shut off, but compressor does
hi! there, continous fan motor when unit was shutt off,since supply source was already cut off specially on fan condenser motor,the supply of your motor was came from relay mounted on your circuit board control panel,there a holding coil to hold the connection between your fan and ac source,shut off breaker for ac unit first before diagnosing ac unit, try to check this out the relay is still activated giving ac source when shut off,the contactor on relay holding your ac supply was shorted,try to check the connection the circuit activating condenser fan relay,eliminate the short circuit,using multi tester test rod,use manual diagram for circuit control board to lessen complicated diagnosing,focus on fan relay ac source then isolate checking the short circuit replace defective relay,contact point of relay are not repairable.take necessary precaution on checking to avoid shock,this a hard task i would suggest that certified ac technician w/ full knowledge of instrumentation should do this.thank's for selecting fixya and have a nice day.
Mar 30, 2009 | Intertherm P3RA-036K Air Conditioner
Lost power- will not come back on
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord. If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable. If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit. Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
Mar 07, 2007 | Magellan RoadMate 700 GPS Receiver
Refrigerators Logo
116 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
