Question about Kenwood KDC-MP208 Car CD/ MP3 Player
I need a wiring diagram for a kenwood cd player kdc 138
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
  • 22 Answers
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
Posted on Mar 10, 2009
foskorider
  • 79 Answers
SOURCE: kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Posted on May 18, 2009
  • 1126 Answers
SOURCE: I need wiring diagram for Kenwood kdc-mp228 radio
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Just input your model number in the third search field, download the user manual, then look on page 25 for wiring connections. Hope this helps.
Posted on Aug 23, 2009
SOURCE: Don't know how to set clock on kenwood kdc-138 without manual
change the tune mode to standby mode. Then press menu button for few second until clock word is displayed on the screen. Afterward, press the center of the main control button on the right side of the stereo system. The time is now blinking and you can start set the time by pressing upward & downward button for hour and left & right button for the minute
Posted on May 18, 2010
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Oct 17, 2011 | Kenwood KDC-138 FM / AM Receiver
My dodge wire diagram for an 04 dodge ram does not match the wires in the dash color wise. i have power to the kenwood reciver but no speaker output in the truck only subs and amp have sound
wire diagrams for both your truck and any kenwood deck they will all be the same
or you can find the speakrs unmask them turn them over and look at the wires conneted to them then match them up with the wires you need to connect the cd player harness
Jun 19, 2010 | Kenwood KDC-138 FM / AM Receiver
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
May 12, 2010 | Kenwood KDC-138 FM / AM Receiver
Install
I hav a problen with ic amplifier of audio KKZ12 I need to remplaice or need more information with this
Nov 23, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Nov 16, 2009 | Kenwood KDC-W3534A CD Player
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Jul 24, 2008 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
459 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
