Model RDO946-7102 Serial # 23368820; Message on
Model RDO946-7102 Serial # 23368820; Message on screen for one month ''Will be shut down soon by Auto Shutdown function'' ?????? How do I remove this? Kent Johnson
SOURCE: laptop won't shut down. It
hold down the power button for 10 seconds
Posted on Sep 05, 2008
joez47
  • 61 Answers
SOURCE: My yahoo mail account shuts down as soon as I open it.
Instead of entering your account at your Yahoo home page go directly to the log-in page at: <https://login.yahoo.com/config/login>
If you still have problems delete all cookies from your browser and see if that works, if not contact Yahoo Customer Support for homepage problems at <http://help.yahoo.com/l/us/yahoo/homepage/troubleshooting/>
Posted on Aug 29, 2009
  • 436 Answers
SOURCE: I have a 1994 dodge dakota and I have the auto
the computer shuts it down, sounds like the engine computer is bad.
Posted on Oct 09, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Auto shutdown and reboot
Your harddrive is starting to go. You will need to replace your hard drive. When you computer starts running slow then it reboots itself is because it is trying to get itself to work properly, but the hard drive is not operating at full capacity. I would back up all of your files as soon as you can onto either a CD or a flash drive, to save yourself from very costly repairs if you need to have the data extracted from the hard drive
Posted on May 30, 2010
  • 6982 Answers
SOURCE: My 91 jeep wrangler 4.0
There is no switch. The relay gets a signal from the computer. If there is no signal from the crank position sensor the computer will not close the relay. If it runs with the relay bypassed, chances are good that the relay itself is bad.
Posted on Feb 07, 2011
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Oasis Elite auto temp control does not allow cold water
Ok, often the actual inlet Solenoid/Valves get "Gummed Up" and need to be "Stripped Down" and put in a bath of solvent for a bit, But, sometimes a couple of good "Whacks" with a suitable tool, will "Free Up" the jammed valve. I wouldn't wonder if this wasn't your problem all along? Anyway try that...
Mar 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Flashing message icon on screen Nokia 6210
check your SIM messages, the icon will flash when you have old messages stored on your sim card.
check : messaging> options> sim messages
Nov 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Computer shuts down as soon as i boot it. it says
Sorry friend, Windows has died on you. You need to reinstall it.
Nov 01, 2009 | Toshiba Portege M400-S5032 Tablet PC
Truck dies while driving
check for clog in fuel pump pick-up screen(inside gas tank)
Oct 30, 2008 | 1995 Dodge Dakota
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Shut Down Message
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Feb 01, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Coffee pot warmer is not working
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
