Question about Radio Shack 21-1926
I need info about the Radio Shack two way radio #21-1935. Can't find a manual. How long should it last with a rechargeable battery. I used a Uniden BP38. Is that recommended? Why did it fail after 2 hours? Thanks.
    President:
  • 1,194 Answers
Thanks for using Fixya.
Visit this Link to download the manual. All the necessary information that you need is in there.
Good luck and have a nice day.
Posted on Jul 16, 2010
  • donnazor Jul 16, 2010
    Ranglo - Thank you! I couldn't find that anywhere. Do you know anything about the battery problem I'm having? The Uniden BP38 lasts less than two hours and Uniden says it's for "recreational" use and doesn't need to last longer. (MY recreation lasts way longer than that.) They also said it has to be charged for 16 HOURS before EACH use! Could this be? Thanks again. The manual really helps.
    Donna
I have a radio shack pro-95 police scanner where can i get a yellow rechargeable battery holder?
Your RAdio Shack store can help you order one. You can use the black holder, but cannot recharge batteries in the radio.
Aug 22, 2014 | Radio Shack Pro-95 Handheld Scanner
Radio shack walkie talkie 21-1914 replaced batteries will not charge
Hi pearl,
A simple problem to solve at last!!!
Inside the battery compartment you should find a switch, which indicates Recharge/Normal, make sure you select recharge if your using these batteries, otherwise no charging occurs.
If this does not work, take out the recharchables and select normal on switch, place fully charged normal batteries into the compartment, making sure you put them in the right way around, close the flap and turn on the radio, if this works, then your battery switch is faulty, however, you can get lithium ion batteries, which will last longer than most other high duty batteries.
The cost of getting these radios is not worth the money, unless you are technically minded and buy the repacement switch and repair it yourself.
Otherwise try all of the above, and remember, when charging batteries that are rechargeable, never leave the radio on, as this can wear out your batteries quickly.
I hope this advice is helpful to you.
Best regards,
Peter
Jan 12, 2013 | Radio Communications
Owner manual
Its a dual trunking scanner which usually means either Uniden or Radio Shack.
Radio Shack has an area on their site where you can download manuals for almost all of their scanners and Uniden may have that as well online.
Bearcat is Uniden by the way who actually makes the Radio Shack units. On Radio Shack you may find a manual similar to the model if a Uniden unit.
Also if you have not tried it GOOGLE the brand and model number with "manual".
Dec 07, 2012 | Radio Communications
What type batteries does the home patrol scanner use
It uses four AA NiMH rechargeable batteries. Need the manual? You can download it, at no cost, here:
http://info.uniden.com/twiki/pub/HomePatrol/WebHome/HomePatrol_OM_FINAL.pdf
Bill B.
Listening in since the 60's
Apr 28, 2011 | Radio Communications
Radio Shack Catalog # 21-1926 FRS radio manual needed. Else tell me if I can change channels 1 - 7 to LO power out. Suspect they are hard coded for HI power out.
In short channels 1-7 and channels 15-22 are GMRS channels are not supposed to be operated by anyone that does not have a GMRS (General Mobile Radio Service) license issued by the FCC. They automatically run on high power. Channels 8-14 are FRS (Family radio Service) and can be used by anyone and are set to run on Low Power. The power is not adjustable with this radio. So now for the manual. Uniden made this radio for Radio Shack. So this manual is for the same radio only with the actual Uniden name. Same exact physical radio same exact manual. http://www.uniden.com/pdf/GMR1038-2om.pdf
Regards, Tony
Apr 22, 2011 | Radio Shack 21-1926
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
Need a manual for Radio Shack 21-1936A radio to explain all the features
The 21-1936 was made for Radio Shack by Uniden. It is identical to the Uniden GMR1038-2
The Uniden version of the manual is available HERE
Jun 11, 2010 | Radio Shack 21-1926
Need a manual for radio shack 21-1936 walkie
The 21-1936 was made for Radio Shack by Uniden and is identical to the Uniden GMR-1038-2
Dec 26, 2009 | Radio Shack 21-1926
Radio Shack 21-1926   Logo
281 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
