Question about Intel Play QX3 Monocular Microscope
Need vista drivers for QX3. had it on my old win 95 computer, but need to install it on my new vista machine. Are there vista drivers for the Intel Play Qx3 microscope?
    Sniper:
  • 72 Answers
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Vista.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
Step 3. Download and extract the QX3 Drivers from:
http://tinyurl.com/IntelQX3driverXP or
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on Jul 24, 2011
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
http://tinyurl.com/QX3-Win7-Files
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
Use with windows vista
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.html
Works for me Win 7 64 bit - same basic OS as Vista. May need to run in compatibility mode, I can't remember. That's a windows Vista/7 feature that allows you to run old 32 bit Win XP programs (right click I think)
May 27, 2012 | Intel Play QX3 Monocular Microscope
Is there a free download so I can run my Intel.Play Qx3 Microscope in Vista
or
Jul 06, 2011 | Intel Play QX3 Monocular Microscope
My QX3 worked wonderfully on my XP system, but I can't load the drivers/installation files on a Vista system.
Sorry, Intel stopped making these years ago. They DID post updated drivers, but long before Vista arrived. Go to the Intel web site, your only other hope is to find a blog of Intel QX3 users, maybe some gearhead updated the driver pro bono.
May 14, 2010 | Intel Play QX3 Monocular Microscope
Old Intel Play microscope needs drivers for Win7 64 bit
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
or
Mar 30, 2010 | Intel Play QX3 Monocular Microscope
Is the qx3 microscope usable on a vista system. and where do you get the qx3 bulbs?
or
Feb 23, 2010 | Intel Play QX3 Monocular Microscope
Have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Mar 23, 2009 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
Step 2. Download and install the QCODINSTL Codecs software from:
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Qx3 miroscope
This worked for my QX3 on my Vista computer!
Feb 01, 2008 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
302 people viewed this question
Top Intel Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
