PROBLEM WITH MICROPHONE
I cant record my voice in the computer..,...
Hello.
Well I just recently got a new mic not really new just more newer than my old one. Well I plug the microphone in and it works perfect with MSN I can send voice recordings so easy. But one day it just stopped working I don't remember if i messed any check boxes or something i have no idea but neither my old mic that worked before will work and neither will my new one work either: I know for sure they both still work because I tested them on my other computer. But my Windows XP Dimension 1300 won't take the mics anymore. Its the kind that you plug in the back of computer in the "red jack" with the microphone picture. I don't know why they won't work anymore can someone please help me. What are the regular regulations or "normal default" configuration for the microphone/audio system I'm losing my hair from this problem I have no idea what i did wrong I might do system restore but I dont know what if im just a check box away please help:(
Thank you,
- Kyle
  • 1 more comment
  • Kyle N Katie Apr 21, 2008
    I also tried the Sound and Audio devices in the control panel. I did the test hardware and it said my sound hardware can't play sounds. But my headphones work perfectly just my microphone.
    Oh and also just found out. When I play a song from Itunes and the same time with the "Sound Recorder" I click on record and without the microphone even turned on or any volume on... The recorder records the song playing like it was really playing. When I turn volume on to hear what it recorded its like playing the song over again but was actually a recording. How do I make it record what I say into the microphone? The computer is recording things when there is no volume at all somehow I have no idea what its doing but I want the microphone to record my voice so I can chat on ventrillo.
    Thanks,
    - Kyle
  • Kyle N Katie May 03, 2008
    Dang we both have the same problem:( we need help!!
I will Give u a solution but u have to do me something
Posted on May 26, 2008
HALP
Posted on May 20, 2008
I have the same problem..can sm1 plz help? :'(
Posted on May 02, 2008
Hello fixya. I just reinstalled windows 7 for my acer aspire 5943G but for some reason i cant get the mic in the computer nor the mic in my headset to work, i dont know if its because i need a driver,...
Check the device manager to see if a microphone is installed. If it is, it may not be installed correctly due to a missing driver or wrong driver. If you find a mic installed, right click and get the properties. Find the tab that says Update driver and allow the laptop to connect to the internet to find the right driver. If no microphone is detected, you can manually install the microphone through the Control Panel under Devices/ Add Hardware. From there, you will select microphone and be given the option to either install it with a disk or by selecting the manufacturer/model.
Jul 20, 2011 | Acer Aspire One PC Notebook
I just bought a new gigaware earclip monoheadset with mic. the problum is i cant seem to get the mic working the sound works great but i just cant get that voice to work
Hello Mithmar hi, try setting the volume for your microphone, (i'm assuming you are using X P) to do this right click the speaker icon (or the mixer icon) on the lower right side of your screen, you will go to the volume controls section, goto options, then properties, select recording. check the microphone, then click apply/ok. On the mixer there is now the microphone slider. Test your microphone by loading the sound recorder program (start, all programs, accessories, entertainment, sound recorder, press the red button) then shout to the microphone, you should see wave patterns on the recorder, your microphone is working fine. at this point let me know your progress.
Oct 09, 2010 | Audio Players & Recorders
I need to get a new external mic for it. Where
Hello if your unit has a 3.5 jack I recomen this two
http://www.tvps.com/Products/ECS-35-mm-Tie-Clip-Microphone---New__ECS-3-prd-5TCM.aspx orhttp://www.tvps.com/Products/ECS-35-mm-Conference-Microphone---New__ECS-3-prd-5CM.aspx
Dec 21, 2009 | GE 35383 Handheld Cassette Voice Recorder
Microphone doesn't work on Gigayte GA-8I915P
Right click on volume properties(on task bar) and select volume properties, check whether the Voice recording with proper device selected.
Dec 08, 2009 | Gigabyte GA-8I915P Duo Pro Motherboard
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
Microphone not working ?
I have seen situations in the past where a woman especially would not modulate her voice well enough to make good sound on her mic, other then that, make sure your mic volume is set fairly high. Also if the situation is not cleared by the previous two suggestions look for newer audio drivers for your system ( whatever that may be ), a.k.a. motherboard audio driver or sound card drivers depending on what hardware you have installed
May 26, 2008 | Microsoft LifeCam VX-3000 Web Camera
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
Jan 12, 2008 | Toshiba Satellite A105-S4334 Notebook
About my mic.
go to control panel:-1-select-sound and audio devices.2-select audio3-in sound recording select your audio driver{creative or other}3-press volume you will see capture screen raise mic volume above and select check box under it.===enjoy recording.
Nov 26, 2007 | Shure Head Set Microphone Microphone
MicroPhone Not working
Download the latest audio driver from intel site. Install it, ur mic will start working.....
Folloe the link and select Sigmatel audio driver
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2374&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#DRV
Nov 19, 2007 | Intel DG965RY Motherboard
404 people viewed this question
 Grubhead
Grubhead
