Tv cuts itself off after about 2-3 minutes
  1. tv is about 8 months old. last nite it started 'popping' and 'snapping' sounds and then it would just cut itself off. at first it would show a picture and it had sound. now its nothiing
    Problem Solver:
  • 5 Answers
Try unplugging it to reset it 7 call the manufacturer. is it under warranty, do you have a dct?
Posted on Apr 25, 2008
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
My Fender deluxe VM soound started cutting out on me last nite-I narrowed it down to the actual amp-outside gig and very hot and humid. Amp is less than a year old-anyideas? tube problem?
Inout connectors are often broken by tripping overr cables resulting in intermittent operation. Wiggle plug and then each pot to see if anything shows itself. Circuit board cracks and broken solder joints are suspect as well.
Jul 24, 2011 | Fender Deluxe VM Tube Amplifier
The lamp has just been replaced and now the tv will only stay on for 30 minutes and then turn itself off. The lamp indicator light is red. We can turn the tv back on and the light goes off. Six months ago...
Did you press the System Reset button with a ball point pin on the front of the set? You might have a ballast going bad if it has never been replaced. But first, the reset button then you may have a thermal switch which is located just above the lamp housing. I test the thermal switches by unhooking (while set is unplugged) one of the wires and then putting an alligator clip jumper between the two wires to see if it last longer than the 30 minutes you mentioned. Lastly, there must not be any dust in and around the fan which can cause overheating. Sounds like you have an overheating problem initially. The thermal switch cuts the set off if there is overheating. And also if the switch is faulty it will cut off the set. Also look in the menu for a temperature setting if this model has a setting such as this.
May 24, 2011 | Mitsubishi WD73727 73" HDTV
Hitachi 50V720 Rear Projection TV
Good Day, douganddawnc;
What ever is popping is locking up the CPU circuit. Call a Factory Authorized Service Center Have figure out what is popping, get an estimate first. Good Luck, big IRISH.
Aug 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
