Question about Dryers
Gas dryer is not heating up, after being moved
  • 1 more comment
  • dotsonian May 11, 2010
    I have no power coming to the ignitor, all other components (thermostats, coils etc. test good) what is the next step?
  • iamrose13 May 11, 2010
    what are solenoids? and where are they located.
    solenoids
    Novelist:
  • 184 Answers
BE SURE THE GAS IS TURNED BACK ON. CHECK THE TEMP SELECTOR SWITCH TO BE SURE IT IS SETTING ON A SELECTION AND NOT BETWEEN SETTINGS. BE SURE IT IS NOT ON FLUFF AIR/NO HEAT. IF THAT IS ALL O.K., THERE ARE FOUR ITEMS TO CHECK IN THE HEAT CIRCUIT.
1. IGNITOR. CHECK FOR 120 VOLTS AT THE IGNITOR TERMINAL CONNECTION WITH DRYER RUNNING.
2. WATCH THE IGNITOR. IF IT GLOWS, CLICKS, GOES OFF WITH NO FLAME, ONE OF THE SOLENOIDS IS BAD. REPLACE BOTH.
3. IF THE IGNITOR COMES ON BUT NEVER SHUTS OFF,
THE RADIANT SENSOR IS BAD.
4. IF THERE IS NO RESPONSE FROM ANY OF THE CHECKS ABOVE, THERE IS A THERMAL FUSE ATTACHED TO THE EXHAUST PORT. IT MAY BE BAD. CHECK FOR 120 VOLTS ON THE TWO TERMINALS OF THE THERMAL FUSE WITH THE DRYER RUNNING. IF YES, THE THERMAL FUSE IS BAD.
Posted on Apr 22, 2008
Thanks!
My solonids were bad, dryer works great now!!
Thanks you Very much!!
John
Zimmerman, MN
Posted on Sep 18, 2008
The dryer is running, but it has no heat. When you place the dial on 30 minutes it doesn't move at all, it just stays on the number. It does run and move the drum around, but no heat at all.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 05, 2011 | Dryers
I have a Simpson autosensing dryer. I moved it and now doesn't dry. It goes but no heat. When I moved it I tilted it by mistake
heatman101][][
Aug 11, 2011 | Dryers
We just moved and our dryer is not heating now and the timer and the timer is not moving i have already replaced the heating element and that did not fix it what else should i look for?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 26, 2010 | Whirlpool LER8648L Electric Dryer
Dryer Tunrs on and runs with no heat and timer never moves
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer ran for over a hour. No heat . timer never moved
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Whirlpool LGV4634JQ Gas Dryer
63942 Dryer: runs air no heat , timer does not move...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
Dryer runs, but does not heat and timer does not move
heatman101
May 17, 2010 | Hotpoint NVLR333EE Dryer
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
Dryer will not heat, plus timer will not move
heatman101
Apr 09, 2010 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer - kenmore 110.73932102
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Frigidaire FDE336RE Dryer
Dryers Logo
488 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
