Question about Dell U0636 Mouse
Non responding wireless mouse and keyboard
I just purchased a new Dell computer with a wireless mouse. I cannot get the mouse to move the cursor nor will the keyboard. Yes, I've checked batteries, talked to Dell, rebooted. What next? All lights work when buttons are pressed, the right click button on the mouse works but not the left and the mouse simply cannot be moved by mouse or keyboard. Dell said I needed to log on and they could do a 'remote' but I explained to them I can't get to the internet because I've not made it past the initial start up phases - therefore no icons and if there were icons I can't get the cursor to move to it. Can somebody help. I'm not a computer expert but do know a little. Thanks.
  • Robert Jul 16, 2010
    Are you stuck on the log in screen then? If so try using the tab key on the keyboard that should let you go through the different options on the screen and get to your password entry. As far as I know using the keyboard arrow keys will not switch between options on the log in screen
    Genius:
  • 1,970 Answers
Mcdevito75 here, Sounds like the mouse itself is faulty, if the right button when depressed returns to position and you hear the familiar click, and you don"t hear that from the left button, then the mouse itself is faulty, ask Dell to send another mouse, it should be on warranttee with your new computer.
Posted on Jul 16, 2010
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
Having replaced batteries on a Dell mouse and keyboard, switched on keyboard and mouse not working. Dell support window says both connected? Cannot move mouse to acknowledge message saying that new device...
If the keyboard is working, try the "tab" key or a combination of the "tab" and "shift,ctl or alt" key.
You should be able to move the cursor to highlight to Ok message, then hit return.
Dec 29, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Changing the batteries does not make the mouse work. the cursor is visible on the screen but will not move. what next?
Have you tried re-pairing your mouse? Should be a button on the bottom of the mouse and a button on the wireless antenna device. Or, If your using a bluetooth mouse make sure bluetooth is turned on, on your computer.
Jun 28, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My problem is similar
Did solve the problem, the cause was a very silly one! The 'receiver' for the mouse signal had got moved around the back of the computer tower when I was changing internet provider. The signal was obviously being partly blocked!
Oct 01, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
My wireless dell mouse isnt working I changed the batteries and still the cursor isnt moving?
there is usually some sort of connect button on both the mouse and then receiver unit that is plugged into the computer, sometimes you have to hold down the connect buttons on each unit simultaneously so that they will connect, i dont know if you have done this or not, otherwise it is always possible that you have a bad mouse, if this is one of those usb wireless mice try moving the usb receiver to a different port and let windows reinitialize it
Feb 20, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Just moved keyboard and mouse not responding.
If you have wireless keyboard mouse try standard ones and see if they work you may get it off power mode
Jul 31, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell optical wireless mouse locking
If your mouse is "locking" the two most likely causes are either due to a battery issue or a connection issue. The first is unlikely since you're saying it started just after you replaced the battery, but you might want to try again if you have other new batteries around that you can use. Also you could try Re-Pairing (if you have the bluetooth wireless keyboard/mouse combo that dell offers) the keyboard and mouse after reboot. step by step Instructions for re-pairing or fixing a corrupted are should be available on the Dell support website and vary depending on the exact model you have.
Jun 28, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless Mouse and keyboard stop working (cursor dissapears)
Your keyboard and mouse maybe using a power saving setting try re-establishing the connection between the keyboard, mouse and the computer. If this helps I'd would really appreciate a FixYa! rating if not please don't hesitate to contact me and I will assist you furthur. Have A Good Day!
Oct 13, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Dell U0636 Mouse Logo
203 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
