Question about John Deere 12" Boy's Single Speed Bicycle
The girl's bike has a long bolt that goes through the handlebars. It is sitting loose in the hole. Instructions included show for the boy's bike and they are not similar. how do you tighten the bolt?
  • 130 Answers
Make sure it has the triangular piece on the end and it itghtens clockwise
hope this helps
Posted on Jul 29, 2010
Can't control the handlebars. They wobble.
IF you are saying the wobble is side to side then the main bolt that goes from the handlebars to the fork is loose.
Aug 29, 2014 | Next Kent La Jolla 24" Girls Cruiser Bike
How to adjust the handlebars on a bike
To adjust the handlebar position on your Raleigh, loosen the nut on the bottom of the stem extension. Use a 13mm or 14mm wrench, whichever fits. Do not use pliers or Vicegrips! It is upside down, so be careful to turn it counter-clockwise while looking at it from the bottom. To change the handlebar height, you need to loosen the bolt on top of the vertical part of the stem. You may need to tap it with a small hammer to break it loose after it is loosened about 1/4 inch. Now you can adjust the handlebar height, being careful not to exceed the maximum height engraved on the stem. You should also carefully align the bars with the front wheel before tightening the bolt. If you do not understand the terms used here, you should take the bike to a bicycle repair shop.
Feb 26, 2013 | Raleigh Krush 16 Girls Bike 2012 - bikes
The handlebars on my daughters Jubilee seem to have fallen downward. She thinks a bolt securing it has fallen out, but it looks to me that if we tightened the middle with an allen wrench it would secure...
There are two sets of bolts here. The first one is straight up and down, is probably the one that takes and Allen wrench and is the one that tightens the handlebar stem - that's the pipe that goes down into the frae toward the front wheel. At the bottom of that bolt (inside the bike frame where you cannot see it) is a wedge-shaped nut that wedges the stem tight. If the stem is loose, then you will be able to stand in front of the bike with the front wheel between your knees and turn the handlebars side to side, and if it is loose enough you will be able to pull the whole stem right out of the bike. On the other hand, maybe you mean that the handlebars twisted down (so that the ends of the handlebars are pointed toward the ground - this would mean that the other bolt or set of bolts are loose. Some bikes have one bolt that clamps the top of the stem around the handlebars, and some have 4 smaller screws that do this. If this is where the problem is, then no, you don't need to buy the Allen wrench, but it sounds like you might need a bolt.
Aug 07, 2012 | Motobecane Jubilee Deluxe
I feel like I'm missing something. I can not attach the handlebars to the bike. I have one long screw, a bolt and some small black cylinder cut on an angle. The instructions are not helpful because...
the cylinder cut on an angle is what the long bolt should bolt to, put the cylinder below the handle bars, and drop the long nut down through the handle bars and into the cylinder, ( the hole in it should be threaded,) only start the bolt so it hangs onto the cylinder, then feed that into the top of the neck hole, where the handle bars slide into,, once the desired height is ok,, tighten that bolt, the cylinder will come up at an angle and tighten the neck and handle bars !! Good Luck
Jul 02, 2011 | Dynacraft Girls 16" Barbie Bike
How to raise the handlebars on a 20" Huffy Rock It
Usually there is a hex bolt or some kind of bolt in the handlebar stem.
Loosen the bolt 4-5-6 turns.
Bolt will move upward.
Then hit bolt down with wrench.
Handlebars should be loose.
Raise handlebars to position.
Hold bolt upward with fingers while tightening.
Dec 25, 2010 | Cycling
I cant figure out how to install the handlebar. The owners manual is beyond confusing.
Go to my tips and tricks page. There are links to Huffy's website with on-line assembly instructions and detailed owners manuals.
The handlebars like in this picture attach to a stem (turkey neck shaped thing). There should be an end with a loop and an end with a shaft. The loop end clamps around the handlebar bottom. Just tighten the screw/ screws. The shaft end will have a long bolt and a wedge. The wedge has to be loose but attached to the long bolt. Insert into the hole in the frame, past the limit line and tighten the bolt. Thats it.
Dec 15, 2010 | Huffy Pro Thunder 12 Boys' Bicycle
Assembling 16" princess bike.
there is a wedge shaped nut and a long bolt that goes thru the top of the handlebars
found a picture for you
http://www.bikewebsite.com/stemwedge.jpg
the small piece in the middle goes on the bottom of the bolt so when you tighten it, it makes a wedge and holds everything in place
Dec 03, 2010 | Cycling
How do we keep up the handle bars on a boys disney 16" cars bike
If the handlebars are "slipping" then you need to tighten the bolts on the stem. The stem is the piece that connects the handlebar to the bike itself and usually has 1, 2 or 4 hex headed bolts that hold the handlebar in place. The Park Tool website indicates that you should torque these bolts to 15-20 foot lbs. This is important because the potential for injury is high if the bars slip at the wrong time. If you don't have a torque wrench then take the bike to your local bike shop and let a professional with the proper tool do the work. This is so simple and quick a fix that they may not even charge you
May 09, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
May 31, 2009 | Huffy So Sweet Girls 20-Inch Bike
John Deere 12" Boy's Single Speed Bicycle Logo
43 people viewed this question
Top John Deere Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a John Deere Cycling Expert? Answer questions, earn points and help others
