Question about Sony KP-65WS500 65" Rear Projection Television
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Try this, it works. I have the same set and have had the same problem for over a year until it got to where I couldn't see a picture. I call a repairman and was told the tubes are bad or going bad and would cost around $1200 to replace all three. He then did a quick fix (I looked over the shoulder) adjustment and said it could last a day, a week, a month or two years. Cost for service call and the adjustment $140. It lasted 3 months, when a telephone pole was hit by a car and knocked out the power. When the power came back on my problem was back. I did the adjustment and its back up and running. One note: make sure you turn it ever so slightly or you will turn the tv off and could damage your tv. Good Luck with it.
Posted on Aug 20, 2010
  • Sony Master
  • 8,457 Answers
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 16, 2010
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
