Question about Craftsman 25cc Gas Line Trimmer
25" /1.5 cu.in. 2-cycle 17" cutting
25" gas trimmer don't seem to be firing new plug just shut off
    President:
  • Craftsman Master
  • 1,545 Answers
Easy way to test plug is to remove it from cylinder head, then ground its hex base to side of engine..reattatch plug wire and pull starter cord...Do this is dim light...need to see a nice blue spark. So, do that...check the plug gap and plug condition (even if new)...if it's NOT firing...try another plug...if same...you will need to pull the engine covers off and check the "air gap" of the flywheel magnets to the pickup legs on the ignition coil module. You can gap it the thickness of a regular business card (.010"-.014"). The gap has to be present for the spark plug to produce a spark.
Posted on Jul 18, 2010
Carburator
You still have a fuel filter, fuel lines and maybe a primer bulb to check too. Make sure you're getting fire to the plug and fuel.
Aug 29, 2014 | Poulan Pro Pp125 17-inch 25cc 2-cycle...
String trimmer tb20cs doesnt seem to be getting spark
hi
that is your ignition wire
along the ignition wire (sometimes called the lead wire)
there is a diode this diode is braking down
and is not repairable
just replace the complete ignition wire
that should sort out your problem
regards
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Clean spark plug 2 cycle engine
Hi chldrz...
Remove the spark plug, clean post and arm with a wire brush, and then use light sandpaper to clean and level the two firing surfaces...(the post and the arm)
Replace plug if it wors fine, if not replace the plug.
Please take time to rate me
Thanks,
Bud
Feb 20, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have no spark checked switch and replaced plug what else should I check
Check the coil. Pull the boot off of the plug. While holding the boot near a metal surface, darken the room and pull the starter rope. If you see a spark, the coil is good, if you don't, you just found your problem.
Sep 04, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have a troy bilt trimmer model tb20cs. has been laying for about four years. gave it a good cleaning ,new spark plug amd fresh gas. starts up fine and idles a short while then cuts off. If you try to...
Carburetor needs cleaning and probably diaphragms. Be sure to completely disassemble and pay very close attention as to where each diaphragm and gasket goes also make sure you remove the needle valve and clean screen.
Aug 25, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I need to know the gas to oil ratio on my 17" 25 cc craftsman weed eater.
4 oz of a generic 2-cycle oil to a gallon of fuel is the typical mix.
I hope this helps.
Jun 17, 2010 | Craftsman 25cc Gas Line Trimmer
Manual
Typically 32:1 to 40:1 for all these models. Use 35:1 and modern 2 cycle oil and you will be fine. :)
Apr 29, 2010 | Poulan 17" T&E Gas Trimmer
Craftsman 25cc Gas Line Trimmer Logo
323 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
