Question about PfaFF Sewing Machines
Pfaff 1222e plastic on/off button popped. This crucial part was spring-loaded with a flimsy spring. There isn't easy access to it. It is a plastic part while the rest of the body is metal. The on/off should also be metal, however I'm requesting a solution if there is one. Thank you very much.
  • 632 Answers
Unless you do your own modification the solution (original switch) is available in ebay. Search under PFAFF 1222 parts.
Posted on Jul 23, 2010
  • Sara Apr 12, 2011
    I replaced mine pretty easily. get the switch as suggested and then open up the underside panel. There are screws to remove the brown ac/dc adaptor box. The switch sits on top of it. Wiggle it out and the switch is very easy to replace. All you need is a small screwdriver. Wiggling it back into place is tricky, so be patient, it will fit back in once you have the wires all lined up out of the way!
  • AussieSewing
    AussieSewing Mar 05, 2014
    Where did you buy the part? What does it look like, can you provide a link so I know I'm asking for the correct part please
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
The on / off button no longer works on my PFAFF 1222E..ant repair shops near south Jersey.
Check your phone directory. I show one in Mt. Laurel and another in Palmyra. You may find others in the Camden directory if you are in that area.
Jan 09, 2014 | PfaFF Sewing Machines
Have needle heating the house of the bobbin case on pfaff 1222e
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Nov 29, 2012 | Sewing Machines
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
How do I time my Pfaff 1222E. The niddle hits the bobbin holder rather than the hole in the bobbin holder
I could write up the procedure but it would be too much for me to type in. Or you can purchase the 1222E Repair Manual and download it. It's pretty easy to work on as long as you have similar tools to clearances.
Apr 07, 2010 | PfaFF Creative 7570
I need a service manual for Pfaff model 1222e
You can download it from PFAFF service manuals in PDF formats. It may not mention an E or an SE after the model #1222 because the difference is just the motor rating and different feet it came with, the rest are all the same.
Feb 01, 2010 | PfaFF Sewing Machines
Can you get me a Pfaff 1222E motor please? Th
You will need a Pfaff dealer or go direct to the manufacturer or even go on ebay and try and purchase a similar model which may be cheaper thanh a new motor and you can then swap motor over.
Jan 31, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
437 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
