Question about Kenmore Refrigerators
Kenmore side by side frig. model 1065757290 I do not get electric to the water vale. I tried a new ice maker but that did not solve the problem.
  • 6,784 Answers
HI. There are only two areas of concern here. The main control board routes power to the inlet valve. If the valve circuits are open, the power will not be accepted, thus, inducing a non operational valve assembly. Now; if the valve test reveals that the valve, itself, is ok, this will lead to a failed main control board(power relay failure).
To isolate the issue, you will need to inspect the inlet valve. Follow my procedure below to isolate the issue.(You will need a multimeter for the electrical section of the test)
Inlet Test:
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink or near the rear wall that your unit is placed). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
NOTE_ If the inlet assembly passes this test: Replace the main control board.(PCB)
Posted on Jul 16, 2010
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
My ice maker on my kenmore refrigerator is not working. a red lightg is flashing on the ice maker. everything looks ok, no ice though!
I had the same issue with my frig. I read on line where Someone open the freezer and ran a hair dryer in it. So I tried it I turned off the water draned the water side out left my door open while I had the hair dryer running for a half hour then turned the water back on and sure enough after the line unfroze and it started making ice. there was a little blurb on the freezer about how much water presure was needed. I found this information just by doing a google search on my model frig.
Nov 24, 2010 | Kenmore Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice tray will not fill with water
you have a bad mixing valve on the back of frig your model should have a duel valve one side for ice maker one side for water replace this valve you will be good to go
Jan 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Oct 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
