Question about Microwave Ovens
Microwave Just stop working No Power Model # NN-H275SF Any Sugestion on what's wrong and how easy it is to fix.Thank you
  • Zouca66 Apr 21, 2008
    Panasonic Microwave Just stop working No Power Model # NN-H275SF
  • laurence_gif Mar 30, 2009
    Microwave won't turn on - no power. Outlet is fine. It had been working for years.
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 23, 2008
Why it blows the light and control board damaged?
It will be best to repalce the board, as card basis, rather than try to make a "Surgery" to it. Gopakumar Gopalan Google
May 01, 2014 | Panasonic NN-H275SF Microwave Oven
Light under the NN-SD297S unit stays on all the time
I see and repair this problem regularly. Details are here.
It's a problem on the control board that occurs when the bulbs short or when they are removed or installed with the power still on.
Feb 17, 2014 | Panasonic NN-H275SF Microwave Oven
Light under the unit stays on all the time
Light under the microwave stays on all the the time
<-- I see and repair this problem regularly. Details are here.
MY PANOSONIC INVERTER SHUTS DOWN AFTER 14 SECONDS MODEL # NNCD989S
Check again.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
Order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 29, 2011 | Panasonic NN-H275SF Microwave Oven
My microwave has gone to "DEMO" mode. Why & how do I correct it
mcdevito75 here The control circuit board may be bad, check with any appliance repair outlet in your area.
Jun 28, 2010 | Panasonic NN-H275SF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
137 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
