Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
My sst25 starts hard and stalls...seems to be sensitive to engine position before stalling...stalls when throttle is opened and when just runnung
Had the same problem with my SST25 and after looking further, noticed something rattling around in the fuel tank. The fuel filter had fallen off of the small fuel line (actually the small fuel line had broken). Removed filter from tank and small piece of broken line from filter connector, and re-connected to small fuel line.
Posted on Sep 06, 2010
Having stalling issues with 2013 tucson
If check engine light not on steady.... May be hard to find problem> One thing to look for is throttle plate coking/dirty.This will cause a problem with the base idle and cause stalling at stop lights and while slowing down. Have throttle plate cleaned and decarbed if it looks dirty
May 20, 2015 | 2013 Hyundai Tucson
Engine stalls but starts right back up
tune up time?
stalls, are cause by 5 major systems fail, (50 causes)
so i have only these questions.
1: can you save the stall with the fast right foot.
???????? was it very easy, kinda hard, or I can;t
dies WOT save the stall, wot -= wide open throttle (yes, pedal to the metal,
Jan 24, 2014 | Jeep Wrangler Cars & Trucks
Vt 275 ICP issues
That sounds like a bad spot in the throttle position sensor. Have you checked that, or substituted a new one for it?
Apr 19, 2017 | Cars & Trucks
Engine stalls
throttle position sensor posibly?
Jul 18, 2012 | 2005 GMC Yukon XL
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
Hard to start running rich & stall
Sounds like a MAP inlet Manifold Absolute Pressure sensor fault. Symptoms of a faulty MAP
  • Poor starting/erratic idling/engine stall - with the MAP not sending the correct inlet air pressure signals to the ECU, incorrect fuel injection volumes then result. The imbalance in the fuel/air ratio often leads to rough engine performance and poor starting and stall. The engine might be kept running at start up by pumping the accelerator pedal
  • Sluggish performance/power ceiling - the engine may seem to perform normally in the lower rev range but will severely run out of power above about 3000 rpm
Poor fuel economy. The ECU tends to supply an over rich fuel mix to the engine in the absence of signal from the MAP resulting in very poor fuel economy. The reason for this is that if the MAP has no signal this ECU assumes 'no vacuum' = fully open throttle = engine is under load. To match this 'open throttle' signal the ECU increases the injection cycle to supply more fuel
How to Check? The MAP has three electrical pins, one for 12 volts (or 5 volts) reference, one for ground and the third (the middle one generally) is the 'signal' output. Put a voltmeter positive connector on the 'signal' pin of the connected socket (back probe by inserting a bit of wire). Apply suction to the vacuum input, even sucking on it with your mouth, should result in a measurable voltage output. At normal air pressure (open throttle) the voltage seen should be 0 volts. As vacuum is applied the voltage output should change to about 5 volts (throttle closed at idle). If no transition seen the MAP is faulty.
Feb 02, 2011 | Chrysler Sebring Cars & Trucks
2006 Envoy stalling when idels and won't stay running
Clean your Throttle body and pay attention to the Idle Air Control (IAC) valve passageway to try to clean the IAC. A dirty or faulty IAC will cause your engine to stall at idle, the job of the IAC is to open the passage way through the throttle body to regulate the amount of air to enter the engine to keep it from stalling when the Envoy is at idle.
Start with the simple and clean the throttle body and inspect any loose or damaged wire leads to the throttle body. Replace or repair any signs of damage.
Thank you for using Fixya and good luck.
Apr 10, 2010 | 2006 GMC Envoy Xl
Engine loses power and stalls
try adjusting the throttle position switch very hard to adjust right car will hesitate , not idle properly and hesitate when accellerating if not adjusted properly.
Jan 23, 2010 | 1991 Volvo 740
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Rough idle/stall
i would start with the TPS ( throttle positioning sensor ).
Nov 11, 2008 | 1997 Chevrolet Camaro
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
376 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
