Question about HP Pavilion dv6000z Notebook
Toshiba Tecra 9000 WiFi
I was given a Tecra 9000 and want to use it to connect to the internet with a wireless router already installed on my desktop (with DSL). Can the Tecra 9000 do this? Or do I need to buy a wireless card/adapter? Everything I've found online indicates that the Tecra 9000 has built-in WiFi, but even with the WiFi switch on, nothing is happening.
  • jenateare Apr 22, 2008
    Okay, so I had to switch to classic view to find the Wireless Connection icon, but then what? It brings up a wizard to set up wireless network, which I did, but then what?
    Sorry for being such a rookie...
This is a known issue with the tecra 9000 series Is your wifi device showing up in device manager??If it isnt then this is your problem this model has issues with your soundcard not showing up in device manager as well that is what mine is doing.I have seen by google search that is has to do with faulty I/O Boards
Posted on Jun 13, 2008
    Genius:
  • 3,587 Answers
It's a wireless connection set up issue..in control panel, among last icons..follow that direction..should get you there.
Posted on Apr 21, 2008
How can i get wifi and lan to connect?
Make sure your wifi button/switch is turned on. It should automatically find and connect. You may have to put in the security key. Also you can go to Start-> My network places, on left set up wireless network. It will walk you thru it.
Apr 27, 2013 | Toshiba Tecra 9000 Notebook
My toshiba tecra 9000 has no drivers for ethernet controller ,vga i cant also configure for wireless lan
You may need to download the drivers from a computer that has Internet access and then copy them to an USB flash memory stick. Then copy and install the drivers on the Toshiba notebook.
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Dec 15, 2010 | Toshiba Tecra 9000 Notebook
I want to connect a wireless Cannon printer to a Toshiba laptop, do I need a certain type of router? I have WiFi and WWAN internet connection, do I still need a router?
The printer needs to be connected to a router.
The router has to be wireless.
The laptop should then be connected to the router in order to install.
The printer shoul have an option to search and connect to a wireless router. After searching an connecting, you have to connect the laptop to the router and install the printer as an network printer.
Sep 21, 2010 | Computers & Internet
I have a at&t modem wifi, and i want to connect the desktop emachine to have internet. how do i do it?
If you mean connect wireless then you need to buy a wireless card for the desktop.
If you mean wired (full speed internet) then get some Ethernet cable and plug it into the back of your desktop and then into your router and install the software your ISP has given you.
Usually the router comes preset so it will work itself once plugged in via Ethernet.
Sep 05, 2010 | E-Machines Computers & Internet
Can't connect Toshiba laptop to Linksys Wireless Routher!!
If this is a new router then the wireless is turned off by default. You need to log on to it and enable it. Don't forget to turn on security such as wep or wpa. Your toshiba should be able to see the ssid or id that each wifi broadcasts. It will also or should be the strongest signal you see.
If the router is older and the wifi is enabled then make sure that the security setting match on the toshiba. ie wep/wpa key. If it is more than about year old then you can have a failure of the wifi section. That means replaceing the router ( I have a stack of different brands all about 1 year old with a dead wifi section).
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Can I access the internet wirelessly with a desktop pc?
Theoretically, yes. you'll just need to install the correct driver on the dell and know what you're doing when you install the wifi card.
Mar 08, 2009 | Dell OptiPlex GX280 PC Desktop
Toshiba Tecra 8000.how do i activate wireless?
it should work even without using the cd based on my experience. just be sure your wifi in your laptop is on. it should let you know if the wifi light is turned on on your laptop.
Feb 05, 2009 | Toshiba Tecra 8000 Notebook
Pls i cant connect my laptop 2 the internet since i formated my system, both wireless and land.i use toshiba tecra A8-EZ8512
I guess you don't install the computer drivers.
In that case go here and download the drivers for you wifi and ethernet card according to your operating system.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1598638&rpn=PTA83U&modelFilter=A8-EZ8512&selCategory=3&selFamily=1073768664&selModel=1598638|PTA83U
Jan 19, 2009 | Computers & Internet
Wifi connection
Hello. The wifi switch should be on as indicated by the light beside it. Please press on Start-Connect to  - then select a wireless network then click Connect. If you are asked for the password, please enter it. Click on Open Network and Sharing Center to check if there is a red x mark between the network and the internet or between the network and the computer icons. If there is none, please launch your internet explorer. Hope this works. Thanks.
Sep 19, 2008 | Toshiba Tecra M2V-S330 Notebook
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
284 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
