Question about Lexmark X1270 All-In-One InkJet Printer
Replaced the black ink cartridge and it comes up no printer cartridge.
The X1270 was working fine but the black ink was running out. I replaced the black cartridge and it won't print and says there is no printer cartridge. I even put the old one back in to see if I could clear the no cartridge thing and it still won't print. If anyone knows what the problem might be, I would appreciate hearing from you.
Thanks,
Carl Wiesener
mrguitar@sccoast.net
  • nellie1259 Apr 28, 2008
    my problem is the same
I had a very similuar problem. When I removed the tape from the new cartiage it seemed to come off with no problem but i found that was still a small pice of tape covering the print head. Check to see that there is not a pice of tape covering the contacts on the cartiage or carriage. The other thing is to make surethe retaining bar does click in place if not it will print eraticialy some yes colors or the black ink won't work.
Posted on Apr 30, 2008
  • Lexmark Master
  • 5,568 Answers
As suggested a couple of minutes ago, with a fresh cartridge installed, disconnect power (unplug) and let the unit rest for an hour or so and then reconnect it.
This may clear an internal error register.
Posted on Apr 28, 2008
My Lexmark X1270 All in One Printer's Black inkjet shows empty when it is a new one?
Click the Printer Properties to get into the Maintenance so you can check the ink cartridges and tell it that there is a new cartridge in black.
May 30, 2012 | Lexmark X1270 All-In-One InkJet Printer
Model x1270 blue not printing all other colours fine new cartridge heads cleaned but still can not get blue or any colour needing blue
take out some hot water in a bolw, put the cartridge head (where ink comes out) for 5secs just dip it into the hot water, use a tissue tap the cartridge head on it see if ink coming out on the tissue. if not then replace the cartridge
Aug 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Black will not print properly
your cartridge is about 100 pages of ink. Try to buy #16 black and #26 color for best results and economy, since #16 have about 250 pages resource.
Mar 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Color cartridge won't print/ black and white is fine
Hi Franelyn !!
giving u some steps so that you get anser to ur question that why your color ink cartrideg is not workign
It might be beacuse of faulty printheads of printer or fauly printheads of cartridge
To check which one is faulty : take a tissue or cloth ...slightly moistened it with water an dtry to clean nozzles of cartridg and observe that some ink is coming out from cartridge or not , if not shake the cartrideg again clean its nozzles , if still no ink comes out that will ensure that the cartride is bad
Nov 29, 2007 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
