Aztek, Rendezvous 2001-2005
Window Systems
- Power Windows
Removal & Installation
To install:
NOTE
Use the correct fastener in the correct location. Replacement
fasteners must be the correct part number for that application.
Fasteners requiring replacement or fasteners requiring the use of thread
locking compound or sealant are identified in the service procedure. Do
not use paints, lubricants, or corrosion inhibitors on fasteners or
fastener joint surfaces unless specified. These coatings affect fastener
torque and joint clamping force and may damage the fastener. Use the
correct tightening sequence and specifications when installing fasteners
in order to avoid damage to parts and systems.
WARNING
Do NOT allow the sealing lips on the outer belt sealing strip to
roll over and point downwards. If this condition is present the window
will not raise properly.
Window Motor & Regulator
To install:
NOTE
Hope helps (remember rated this).
