Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
21 hp briggs on husky mower runs fine but intermittently acts like it is flooding ie.it starts losing power and i can see small amount of black smoke.if i pull the choke on easy it will stall.sometimes this is mild and others it will just barely sputter.
I had the same problem with mine. I talked to briggs help line and that was useless and also talked to 6 other repair shops. Seems to be a dirty little secret they are keeping about the defective carbs they use. Only way to fix it is to get the redesigned carb they have out now. They changed the fuel bowl and solenoid assembly. Carb kits did me no good.
Posted on Oct 06, 2010
Act like it is flooding out at high rpm
try cleaning the air filter as it is probably blocked
Jul 13, 2014 | Briggs AND Stratton Intek Briggs &...
21 hp twin briggs engine cranks runs
Try replacing your air filter
Sep 20, 2013 | Craftsman Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Engine backfires, runs only at low rpm, seem to be flooding
The unit in the bottom of the float bowl is an anti fire solinoid, when the ignition is switched off a small needle is inserted into the main jet in the carb, the idea is to stop fuel entering the engine as the engine shuts down, if fuel enters the engine as it is shutting down it is sent out the exhaust valve and into the hot exhaust, this in turn can and does cause a massive bang, you can test this by removing the unit from the bowl, switch the ignition on, the centre needle should retract into the units body, if not it is bad and will stop the engine from reving.
Apr 06, 2013 | Craftsman YT 3000 42" Briggs & Stratton 21...
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
773 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
