Question about HP LaserJet 1200 Printer
Printer will not print but, will print test page
  • HP Master
  • 1,606 Answers
Ok if it is able to print the test page we know that the problem is either going to be a cabling issue a driver issue or a printer port problem. I'm going to assume that this is the printer test page not the test page that windows would start.
The first thing to check is the cable. Make sure it is properlly inserted in both ends.
Check your operating system to see if it is trying to print to the correct printer and type. In windows you can look under printers and faxes and see what printers are there. The 1200 should be there and it should be set to be your default printer. If it is set as the default then you should see a checkmark. If it isn't check marked and you don't select to print to it then it will try to print to the one that is default usually a fax. Right click again and open the properties window. There should be a test page button. If your connection are right the printer will print a test page.
There should be a connections tab, if you look there then it should show the connection type. If it is a printer port it will show as printer port, if it is usb then it will show as local port. If those are correct then we next need to look at the port to see if they are working.
We can look under control panel to see if the printer port and usb ports are working. If this is a usb printer the easiest way is to stick another usb device into the port. We would also want to try the printer in a differant port. So you want to change it and then see if it is talking yet so try to print a test page from the printer driver tab. Don't just try the usb next to what it was plugged into, try all of them. If there is a problem with the usb the two ones close together may share the same controller and both might not work. Also you may have a device conflicting so unplug any other usb devices and see if that changes anything, you have to anyway to test it in the other ports. Testing the parralel port or printer port is harder, the easiest way takes a tool. So we will cheat and plug the printer into a differant laptop or desktop. If it starts working then we now know the issue is with the cable end at the computer or the usb port on the computer.
I have never seen the printer side of the interface die. The majority of times it was a cable problem or one of the connectors. The odd time it was the computer port with usbs being the common one.
Posted on Jul 16, 2010
    President:
  • 1,194 Answers
Hi Justusroll,
Thanks for using Fixya.
First of all check that there are no pending documents in your printer's tray.
When your printer is connected to your computer then at the right hand bottom of the screen (where time is displayed), you will see a printer's icon. Click on it and if you see a list of documents then cancel them all. Also see that the printing process is not paused.
Good luck and have a nice day.
When printing, it keeps printing the test page first. How can it stop printing the test page??? thx
reset the printer by pressing the reset botton for atleast 5seconds. then it ask for printing the test page.............. and you have to print the test page completely... otherwise it will ask for printing the ttest page at every print......................
then switch off the printer and again on it..........
then you will see th\at the problems will be solved..................
thnx
Jun 22, 2011 | Epson Stylus Pro 4800 InkJet Printer
I have a printer HP DJ 5940 and i have a problem with my connection. in status the printer says ready but when i try to printtest page says test page faild to print and i can't print. Any idea Manolis
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
Aug 07, 2010 | HP Deskjet 5940 Photo InkJet Printer
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
How can I print a test/configuration/demo page?
open & close the top cover for 3 times while the printer is it will print a stand alone test page, also u can print the test page from the computer, if u r using xp then control pannel> printer & faxes> u will see the printer icon fro ur printer, right click on it , go to properties, click on print test page,
if u r using win 7 or vista in that case click start n in the start search type printers & hit entre the printer page will open, from there u will see your printer's icon so do exact same, u will get the test page.
cheers
Apr 01, 2010 | HP LaserJet 1020 Printer
My kodak printer is not printing my word documents
HAVe you tried to print on other application?
try to do some print test page using you computer. If your using windows XP you can print a test page under control panel and printer and faxes, Just click the icon of your printer then properties. If the test page printed the test page it means computer is fined
Just check the settings of word document. make sure your printer is selected as default printer
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer scans and prints ok. but doesn't print documents from my documents. Microsoft reinstalled new driver with no results. Printer makes noise as if it were going to print but all I get is a blank...
first try to print windows test page from the pc and check out.if windows test page prints ok then try to print from my documents.but if windows test page does not print that means drivers are not got properly installed.
click stat---click settings --- click printer and faxes-- a page will get opened-- on that page you will see you printer icon-- right click that printer icon ------ and click the last option called properties ---- a page will get opened.---- on that page on lower right corner you will see print test page option--- click that and see if that page prints.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | HP PSC 2175 All-In-One InkJet Printer
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP LaserJet 1200 Printer Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
