Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Amana Bottom Freezer, Model DRB1801AW. purchased in 2002.Compressor is warm to the touch and you can feel a slight vibration when compressor is running. Evaporator fan is on when system is on "cooling". Condenser fan motor is running. If I advance the defrost control clockwise I can hear the stop and start clicks of the defrost timer.
Freezer is not cold and refrigerator section is not cool.
I have replaced the "start capacitor and the overload relay" thinking that perhaps the compressor was at fault, to no avail.
Any advise will be most helpfu
Thanks
Joe
    Top Expert:
  • Amana Master
  • 83,081 Answers
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Posted on Apr 20, 2017
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rockitman187
  • 2559 Answers
SOURCE: Intermittent Amana side by side
Although,I think this is the condensor fan or condersor clog
here is more info on the part in question.
On the compressor,under the cap where the wires are connected,you should see a small disk (about the size of a quarter)wired in between the the power post,It should have 1 wire to a compressor post and one to a power in wire.
It is called a thermal snap disk
Please rate this a fixya
Posted on Jan 30, 2009
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 531 Answers
SOURCE: Amana DRB1901CWO Not cooling. Freezer melted, fridge not cool.
check and see if condenser fan working call service
Posted on Apr 01, 2009
aasc
  • 1606 Answers
SOURCE: Refrigerator does not cool.
Ok , I'll help you .
Pull the refrig out from the wall , and unplug . Remove the 8 " X 10 " panel on the back of the refrig . Inside this panel , is the main control board .
Remove the blue plug with 3 larger wires going to it . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire , and remove about 1/4 inch of insulation , from both ends . Insert 1 end of the wire , into the slot of wire2 , and the other end , into wire3 .
Plug the refrig back in .
After about 2 min , look inside the freezer , behind the bottom crisper , and look for a red glow . This glow , is the defrost heater .
If no glow , this is an indication of a shorted defrost heater , or bad defrost thermostat , both of which are located behind the rear freezer panel . Unplug the refrig , and reinstall the blue connector , and the 8 x 10 panel .
The pt # for the heater is WR51X10101 , and the part number for the defrost bimetal is WR50X10068 . Both should be replaced . The heater is at the bottom of the coils , held on by 2 screws , and the thermostat , is clipped on the top right of the coils , with a blue and pink wire going to it .
If you do see a red glow , reasemble as above , and remove the rear inside freezer panel . At the top of the coils , on the left , you will see 2 white wires attached to a 1 " piece , which is clipped to the coils . This piece is the # 4 thermistor ( evaporator thermistor ) . Pt # WR55X10025 . Also replace the # 5 thermistor , ( freezer thermistor ) which is at the bottom of the panel , slid into a holder , also with 2 white wires going to it . Both thermistors , sent readings of temp , by coldness resistance , to the main control board , which then decides if it needs to defrost , or cycle off due to coldness reached .
Posted on Oct 11, 2009
I have an Amana bottom freezer refrigerator, Model BR18V1E purchased in 2002. I opened it and the refrigerator was not very cold and didn't hear fans blowing. I opened the freezer and my ice has...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Amana Refrigerators
The refrigerator is 2 yrs old and has completely quit cooling in both the refrigerator and freezer.
I looked at your wiring diagram. This ice box has automatic defrost controls. That means the temp is regulated by a computer board. Their are some diagnostics you can perform on some of these models.
Your ice box appears to be a midrange control model. Click HERE for a diagnostics video
Amana International bottom mount service manual featuring midrange electronic controls
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer on amana model arb8057csr quit working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 29, 2010 | Amana ARB8057CSR Bottom Freezer...
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have an ARB2257CSL Amana bottom freezer refrigerator and the fridge portion just stopped cooling things down. The milk is warm but the freezer is working fine. We put the fridge all the way up and it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 09, 2010 | Amana ARB2257CSL Bottom Freezer...
My amana abd2533dew purchased in 2005 has stopped cooling.Woke up with the freezer blowing warm air,all food thawed. refrigerator temp falling fast.Service can't come for 3 days? I have an extended...
If the freezer compartment is blowing warm air, then you either have a problem with the compressor (or a freon leak) or a problem with the fan located next to the compressor (at the back of the machine).
Attached to the compressor is an overload protector, which is most likely what broke, but if you are covered by a service contract your best bet is to wait it out and let them fix it. One thing that might have caused the overload to break is too much dust on the condenser (the radiator looking thing underneath the machine, accessible from the front).
Jan 01, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
173 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
