Question about Dryers
Hello, i have a Maytag MDET336AYW dryer, I need to know where all of the wires on the timer switch go. Preferably in a Counter Clockwise direction starting from the top left terminal. Thank you.
  • thesoups2322 Jul 16, 2010
    I have gone over the wiring diagram for this timer, and yet, it makes no sense, Is there an actual picture of said timer that i can color match off of?
  • thesoups2322 Jul 19, 2010
    I understand the terminal abbreviations, and i have hooked them up in correspondance to their terminals. I was able to take one picture of the switch before my spouse became grab happy with wires. And it shows two individual white/black stripe wires on terminal M, not WH. And terminal WH is blank?!? This makes no sense to me but this was before we removed anything. I put all colors according to where their color codes are, and i put the two white/black wires according to the picture on terminal M. Now, I have no light inside of the dryer, i do have incoming voltage from the wall. I understand how a normally open normally closed switch operates, and i have hooked the 3 wires up according to the prints which proves my knowledge. But like i said, no light, no movement, the dryer makes no attempt to work. I have checked the TWO thermal fuses that i could find and they as well are in working order. Is there something i am overlooking? perhaps another fuse? Thanks for your time and advice.
    President:
  • 949 Answers
My name is Phil, I was reading your posting and would like to help. From what you last described I am going to ask a silly question.
You say you have power at the wall outlet. Are you sure you have enough power. What I mean by that is you need to have 240 volts, 2 legs of 120 volts and neutral. The light works off of L2 on your dryer and the motor off of L1.
If you have a volt meter, you should read 120 volts from either leg to neutral and 240 volts from side to side of the outlet.
Posted on Jul 19, 2010
  • Dryers Master
  • 8,220 Answers
Your wiring diagram
Wow this one does not have that many terminals. Black wire goes to one side of the timer motor, pink or pink and white wire goes to PK, Red wire to the RD,terminal, gray wire goes to GY orange wire to OR terminal Yellow wire goes to YL:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1340516&pkw_=basket&model_id=5174209&NewWindow=1
Posted on Jul 16, 2010
    Sir,
  • Dan Webster
    Dan Webster Jul 20, 2010
    Show a picture
  • 6,784 Answers
HI. The only way to do this correctly is to follow the wring diagram. This is a complete diagram. Each wire is color labeled. Example: BK= Black, OR= Orange, PK=Pink, GY= Gray, RD=Red and WH=White. Click Here to be directed to the wiring diagram for the timer and other components.
  • 6 more comments
  • Michael Masters
    Michael Masters Jul 16, 2010
    YL=Yellow
    BU=Blue
  • Michael Masters
    PU=Purple
  • Michael Masters
    No, there are not color picture of this device. The wiring diagrams are standard to most techs......
    wow....
  • Michael Masters
    RE:
    No, there are no color pictures of this device. The wiring diagrams are
    wow....
  • Michael Masters
    I clearly posted the color legend and there definitions... Are you saying that you cant read the color definitions?
    Its quite simple. BK= BLACK PU=PURPLE etc...........
  • Michael Masters
    PIC
  • Michael Masters
    Michael Masters Jul 19, 2010
    The door switch has failed. Use my procedure to confirm:
    The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
    Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
    Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
    Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
    If the switch does not test as described, it should be replaced.
  • Michael Masters
    Your new door switch will be quite different. It will have three terminals, not 2. Replacing your failed door switch will correct your problems.
Does this timer count in hundreds of seconds or just seconds
Most timers count in 10th of seconds as they rotate, but minutes are shown on the dials. No need to know, as you spin the timer wheel, it just registers the minutes you set on the dial, not the seconds. Always turn the dials ONLY in the direction they automatically travel, not in the opposite direction. Forcing the dial in a counter-clockwise direction can cause breakdowns.
Nov 03, 2014 | Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Maytag Dryer Error code F-02
Somewhere in the instructions for your Maytag dryer there is a comment or direction to rotate the timer knob only clockwise. Otherwise you shorten the timer's working life considerably and wind up having to replace it.
Mar 18, 2014 | Maytag Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Igniter only glows on permanent press cycle and not timed cycles
I unplugged the ignitor and put the leads from my multi meter into the plug to monitor the signal to the ingnitor. I got 120 volts only when I turned the timer switch counter clockwise or to the permanent press cycle. When I turned the switch clockwise or to the timed cycle I wouldn't get the voltage to the ignitor. While in the timed cycle, I turned the switch counter clockwise and as I started counter clockwise pressure on the switch knob I got 120 volts to the ignitor. There is a little play in the switch and when taking up the play in the counter clockwise direction the switch would engize the ignitor. The timer switch is bad.
Feb 05, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer won't start
check your circuit breakers for dryer they may have tripped whenlights went out. write back if not the problem let us know a little more about problem
Jan 30, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
My maytag dryer MDET336AYW won't come on
probably have a back door switch. look and see if when you close the door it closes the switch
Jan 04, 2009 | Dryers
Removing Timer knob on Kenmore Electric dryer
Normally, to remove the timer knob, simply push in on the timer knob and turn the knob counter clockwise. it should unscrew itself. If it does not, the shaft inside the timer has broken and the shaft simply free wheels so then you need to take a needle nose pliers to hold the shaft and then you can turn the knob or pull it off
Let me know if you have any further questions
Jun 04, 2008 | Dryers
Dryers Logo
128 people viewed this question
Top Dryers Experts
