Question about Lincoln Welding Tools
Why can't I get a spark from my 650 linclon
Why can't I get a spark from my 650 lincoln welder, 6 cyl?
    New Friend:
  • 81 Answers
You should check your ground clamp.
Ensure that you have your electrodes set to the correct polarity.
Consult your manual for electrode -/+ settings.
I don't know your level of experience, so please understand, i am just checking all options.
Is the welding wire fed through the contact tip? Are your electrical connections secure?
These are a few items to start with.
Good luck.
Posted on Jul 20, 2010
Lincoln hd 140 barely sparks
Try switching the a,b,c,d back and forth a couple of times a corrosion builds up and causes a week contact so there isn't enough voltage to work . This has happened to me a couple of times . The first time the fan was running and I had no wire feed action and then a local repair guy told me that corrosion is very common with the portable Lincolns . You shouldn't even have to take it apart to clean it just switch it back and fourth and that does the trick. Good luck.
May 06, 2014 | Lincoln Electric Lincoln Easy MIG 140...
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
Mar 03, 2013 | Miller Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I have a 2002 Lincoln Continental which is misfiring on spark plug #6 and running too lean on bank 2.
Bad COP Ignition Coil cylinder #6,
causing lean O2 Sensor code on
bank 2, where cyl #6 is
$70.00 at auto parts and 15 minutes to install,
one 10 mm bolt
1.2.3.4. Pass
5,6,7,8, Driver Side
Change both front O2 Sensors if
over 100,000 miles on them
Both do it yourself. Hour total time
Mar 17, 2011 | 2002 Lincoln Continental
I have the lincoln 180 my wire is being fed but not getting any spark any ideas?
First make sure you have a good ground clamp and the line well tight to the machine. This problem is a common one.
Jan 07, 2011 | Lincoln Electric Lincoln Easy MIG 180...
I have a 2000 v star custome 650. i have a weak spark on the front cyl,and no spark on the rear cyl.if i bump the rear cyl coil i get a full spark. how can i fix this..
Hi, Don and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
05 Star 650 Custom second cylinder not getting spark
2005 650 with no spark at rear cylinder Yamaha Star Forum
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
Yamaha star XVS650P Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 03, 2010 | Yamaha V Star Classic 650 Motorcycles
Welding Tools Logo
64 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
