Cooling fan 98 cavalier does not work relay, fuse, fan, ect all good. does not come with a/c. comes on when ect unplugged ect has been replaced
This system is controlled my the power control module. when you need it the system sets a ground to the system
you can run a ground to the blower motor and it should come on. but you will need to put some kind of switch on it to cut it off so it will not kill your battery or just replace the module.
Testimonial: "thanks for the input, i need to ohm the ground to the pcm, hopefully it's a bad wire. i just got the diagram for the pcm. we'll see God bless"
