Question about CDV Software Blitzkrieg for Windows
Wie kriege ich CDV Blitzkrieg unter Windows 7 32 bit ans laufen
2 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: Did the CDV Software Codename
It works with windows 64 bit and also 32 bit.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Software&s=codename%20panzers
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 08, 2011
Please help
Change the compatibility settings of the .exe file that executes the game to an earlier o.s. That should work. If it is REALLY old, try DOSBOX
Apr 16, 2014 | CDV Software Blitzkrieg: Rolling Thunder...
Blitzkrieg will not work on windows 8.1
Blitzkrieg is a B***h of a game to get working on anything after XP
I own a copy myself and on windows 7 it runs really fast and the graphics are all over the place.
Unfortunately I dont think you can get it working unless you mess with the compatibility settings.
Nov 23, 2013 | CDV Software Blitzkrieg Anthology for...
I've uninstalled and re-installed Blitzkrieg Anthology with my CD-ROMs and I am not able to play the game, everything loads fine but when I try to play the game the screen map does not pop up, gives me...
Try updating your video card drivers. However, according to the specs, it's not supported for vista.
Vista site is equally unhelpful.
http://www.microsoft.com/Windows/compatibility/windows-vista/Details.aspx?type=Software&p=Blitzkrieg%20Anthology&v=CDV%20Software%20Entertainment&uid=&pf=36&pi=6&c=PC%20Gaming&sc=Strategy&vd=all&os=64-bit
Had a quick browser on the forums. Have you tried this vista dual-core patch?
http://bkpforums.com/phpBB2/viewtopic.php?f=58&t=3275&p=108961&hilit=screen+map+vista#p108961
Best of Luck
Jun 11, 2011 | CDV Software Blitzkrieg for Windows
Meine linse ist kaput wie kann ich sie raparieren
Ich denke nicht, du kannst. Zugriff auf das UMD-Laser erfordert in der Regel unter das Ganze auseinander. Es ist riskant, und es nicht wert. Schicken Sie es zurück zu Sony, wenn es noch unter Garantie. Wenn nicht, können Sie versuchen, Custom Firmware auf der PSP setzen, aber darauf achten, dass die PSP kann es erste Handgriff, wie man es permanent zu brechen, wenn es nicht ist. Nachdem wir Custom Firmware drauf haben, können Sie Spiele auf Ihrem Speicher-Stick laden und spielen Sie sie direkt aus dem Stick gratis. Sorry, wenn es irgendwelche übersetzungsfehler, ist Deutsch nicht meine Muttersprache.
Feb 18, 2011 | Sony PlayStation Portable (PSP) Console
I have tried everything, how can i run this program? I have windows 7 64-bit and i need help!! Any solutions?
This is an older game so it may not be possible, but there are a couple things I would try. I have linked to sites with a full description of what is needed for each suggestion.
Compatibility Mode and Set CPU Affinity:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
patch your game:
http://www.fileplanet.com/124619/120000/fileinfo/Blitzkrieg-v1.2-Patch
A quick search found other users who got Blitzkrieg to work, but I found none that were using Win 7 64 bit. 64 bit versions of windows seem to have more compatibility issues with older software than the 32 bit.
Assuming you have tried all of this, you might consider a dual-boot option for Win XP, or get an older PC for this and any other Win XP games (that don't like Win 7). I have found several of these.
Jan 29, 2011 | CDV Software Blitzkrieg for Windows
Ich habe einen speedport W721V und weiss nicht wie ich Āµorrent zum laufen bekomme
Kommt darauf an was du meinst damit, daß es "nicht lauft". Am unteren Rand des Fensters von µtorrent sieht man in der Mitte der Statusanzeige einen farbigen Punkt. Wenn dieser ROT ist, hast du wahrscheinlich ein NAT-Problem (vorausgesetzt, du hast deinen Port in deiner Firewall freigegeben. Wenn noch nicht, dann solltest du es jetzt tun. Wähle einen Port im Bereich zwischen 49152 und 65535, der ist nämlich bestimmt frei).
Meistens kommen NAT-Probleme daher, weil der Router den Verkehr für unautorisierte Ports blockiert; das ist eine Sicherheitseinstellung, kann aber auch mit normalen Datenverkehr Probleme machen. Neuere Router haben oftmals die Unterstützung des UPnP Protokolls eingebaut. Schau dafür in deiner Routerdokumentation nach, wie du diese Funktion im Router aktivieren kannst. Danach setze in µtorrent unter: "Optionen" "Einstellungen" "Verbindung" "Aktiviere UPnP Port Mapping" einen Haken. Das farbige Symbol (NAT-Anzeige) sollte von gelb auf grün wechseln, sobald du erstmals eine eingehende Verbindung hast (natürlich wenn du einen torrent laufen hast!). Wenn es aber rot wird, oder du im Reiter "Protokoll" eine UPnP-Fehlermeldung erhältst, dann schalte UPnP ab und leite deinen Port manuell weiter. Sollte das nötig sein musst du den Empfangsport für µtorrent einstellen. Dafür unter "Optionen" "Einstellungen" "Verbindung": einmal auf den Knopf "Zufälliger Port" klicken, und notiere dir den vorgeschlagenen Port. Diesen Port musst du jetzt in deinem Router weiterleiten (forwarden). Du kannst aber auch einen Port deiner Wahl verwenden. Jetzt den Haken bei "Bei jedem Start von µtorrent einen zufälligen Port wählen" rausnehmen. Damit bleibt der Port immer gleich. Wie gesagt, idealerweise steht bei deinem Port z.B. '34250-34377 Unassigned' (wenn du z.B. den Port 34343 gewählt hast). Das sollte es sein, wenn du noch Hilfe brauchst lass es mir wissen.
Wenn diese Lösung geholfen hatt, bitte klicke auf RATE :)
Jan 28, 2009 | Computers & Internet
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
CDV Software Blitzkrieg for Windows Logo
119 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
Steve Allison
Steve Allison
comandomcl8
Level 1 Expert
Bill Boyd
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
