Question about Philips Televison & Video
MODEL: 60PP9202/17F Convergence Template ST4179
I need to know where we can borrow or rent A Particular Rear Projection TV from Phillips Model(60PP9202/17F) Convergence Template Model (ST4179). I have googled online and they cost around $100 Bucks and we Are Repairing the TV Ourselves. This would almost double the cost of repair. Does anyone have one that we can borrow or rent?
wyoed1
  • 211 Answers
SOURCE: double picture/red shadow
You may need to sinlpy adjust the convergence. Check your owners manuel for the proper way to access the convergence screen and follow it step by step. If this doesn't work, you may have a bad convergence chip. Here is my generic post for convergence.
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
SOURCE: Model NO:60PP9202/17F
I have a Phillips Model # 60PP9202/17F, when my wife turns it on it makes a chirping sound but after that there is no sound or picture.
Posted on Jul 07, 2008
  • 41 Answers
SOURCE: convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Posted on Oct 07, 2008
  • 38 Answers
SOURCE: 60pp9202/17f Cant adjust Red Horizontal convergence
chang the convergence ics
Posted on Oct 13, 2008
daniel719
  • 240 Answers
SOURCE: phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Posted on Jan 13, 2009
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
Convergence PROBLEM pHILLIPS mAGNAVOX 60" rEAR pROJECTION
All i can say is that this is very common.May be it is not the convergence circuit in this case. it is the power supply not giving the convergence circuit the power it needs to run. there are several parts that need to be repalced here.
Or may be the convergence amplifiers need to be replaced. They're on the Small Signal Board (the one with the tuner[s] on it) and the part on the amp's (there are two on them, replace both) start with STK and will be followed by some numbers and pssosibly letters, such as STK392-110.
Goodluck,
Please don't forget to rate the solution.
Apr 11, 2008 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
How can I find a "convergence circuit" for my 8 year old 60 in Phillips projection TV? Could I install it myself or would I need to hire an expert to do the work?
There are no a whole DLP tv model Philip convergence board out there to buy.U only can buy a convergence kit,came in parts like 2 STK convergence ICS and some or all of it resistors parts for sale.Hire a shop to fix ur DLP tv convergence board.They'll charge u like $300-350 for parts and labors.
Nov 09, 2010 | Philips 60PP9202 60" Rear Projection...
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
