Question about Craftsman 25cc Gas Line Trimmer
I have a craftsman 358.796121 weedeater. I took it apart to store for the winter. When I put it back together the motor runs but the bottom of the trimmer turns until I put the lines up to the grass then it stops and will not turn.
    Problem Solver:
  • 6 Answers
Sounds to me like you may have either blocked ports in your carb, or your fuel line is too high in the tank when to go to use it,
Posted on Jul 27, 2010
I have an old 315-11441 Craftsman Drill. I took it apart to fix the switch and in the process something must have shifted in or around the gearing. After putting back together when I power the drill I hear...
With these types of electric motors there is an armature, (the main brain of the motor) it has all the copper wiring wrapped around it and slides between two carbon brushes into the armature housing. If you took out the armature, there is sometimes a very thin peice of metal at the top of the armature which slides into the plastic housing above the armarture and creates a spring loaded "seat" for the armature, if this little shim looking thing fell out, you will need to find the old one. Without this tiny peice of metal the armature in the motor will have play in it causing the brushes to wear to one side or the other prematurely, the brushes have to wear evenly. Sometimes the brushes are spring loaded as well for a self-feed type deal. If these springs are missing the same thing will happen. Also one or both brushes could be in backwards. Check and make sure the brushes (black carbon and rectangular shaped) are positioned to support the spin of the armature. Lord, I hope this helps. I worked with small electronic motors over 15 years ago. I worked at the place for a few months, and didn't think I still remembered everything,
Aug 12, 2010 | Craftsman 3/8" Corded Drill
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Putting the carberator back together.
one end to the govenor other end to the throttle on carb
Jun 30, 2009 | Craftsman Garden
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
May 17, 2009 | Craftsman Garden
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Craftsman 25cc Gas Line Trimmer Logo
227 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
