Question about HP Compaq Presario V5000Z Notebook
V5000 thanks ill try that and ill get back to you to see if it was really helpful or not
Please give me help my laptop compaq v5000 windows xp instolation problem the massage is your harddisk no connact & chakk setup i chak setup partation is active so instolation proble please help me
Posted on Nov 07, 2008
Have a Sony 32" Bravia TV & Yamaha RX-V5000 Receiver. Unable to get the sound to come from the Stereo speakers connected to the RX-V5000 if watching TV. However, can get the Radio to play through the TV...
You probably want to connect the av Audio output from your tv and connect to the RX-V5000. The audio that you are getting from Radio through the tv is probably coming from the output of the RX-V5000 coming to your tv, to which the desiredd route is the other way.
The Outputs at the back should be labeled to tell you which channels are inputs or outputs.
Oct 09, 2013 | Yamaha Audio Players & Recorders
Were do i get a la-3181p v5000
Ebay. Any V5000 full-featured AMD motherboard will work. There are several with very minor internal updates that really have no functional effect. Reconditioned is as good as new. Look at the connectors on the seller's photo to be sure you are getting the correct PC board. There are many confused eBay listings.
If you buy a used or reconditioned board, check the USB connectors before installing it. USB abuse and damage is a frequent problem.
Buying Hint: You may find that a damaged V5000 with a good motherboard is a better buy.
Good luck.
Sep 15, 2010 | HP Compaq Presario V5000 V5100 V5200 V5300...
Hello GOD BLESS YOU all. my latop is compaq presario V5000
You can download latest drivers for your model here
Apr 09, 2009 | HP Compaq Presario V5000T Notebook
Function f4 key in B&W
You need to update the software comes along with your preserio v5000. Try to install the software again from the CD.
Jan 20, 2009 | Compaq Presario 700 470024-192 Notebook
Blank screen problem witn presario v5000
This will not kill your computer don't worry.
What would be mt suggestion for you, please get your presario v5000 reimage with all the drivers.
Thanks
Aug 25, 2008 | HP Compaq Presario V5000Z Notebook
Replacing harddrive
Service Manual of V5000:
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
Service Manual of V2000
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
yes the hdd of the V2000 and V5000 is interchangeable. it uses both IDE type hdd.
Apr 11, 2008 | HP Compaq Presario V2000 Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Remove HD (optional, just in case u shake up the unit too much),
(i)
Remove battery,
remove 2-3 screws found in the battery comparment
(ii)
Pry up the keyboard bezel/power button cover by accessing slots above F2 & PAUSE keys,
it will feel extremely tight but work it a little,
try not damage your keyboard (try and pry/separate the back of the cover first).
(iii)
Look top-left,
u'll see a cable leading from the motherboard to the display
(iv)
CAREFULLY unplug the white connector and replug FULLY FULLY.
PLEASE pry and push the white connector housing ONLY not the fine wires.
THAT SHOULD BE IT!
If not i can take u to more advanced testing with meter and probes.
Oct 20, 2007 | Compaq Armada 1700 Notebook
HP Compaq Presario V5000Z Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
