Question about Delphi SKYFi3 XM Radio Receiver
My unit will not turn on. I've pushed every button on it.
  • 4 Answers
Press both the MODE key and the VOLUME control button (upper Right side) UP for a few seconds and the unit will re-boot. Works every time the unit get cranky (no pun intended!)
Posted on Aug 13, 2010
  • rglobo Sep 07, 2010
    I have the same problem, I have had my radio a few years and pressing the mode key and volume buttons used to work for my radio but does nothing at all now....tried it in power unit dock and without it, just blank screen does not power up....any other solutions to this problem besides junking this radio?
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Brush drive unit not turning, button on side has been depressed as reset, button on handle has power to it and drive appears to have suitable tension which would suggest drive belt has not snapped.
Sorry to hear you're having difficulties with your DC24. Although you've already tried pressing the reset button, you might find it helps to use something like the blunt end of a pen or pencil to do this, and make sure you push it in firmly until you hear an audible 'click'.
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver switch next to the red on/off switch.
Hopefully this should resolve your issue. However, if you're still having difficulties, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and provide the assistance you need.
Kind regards
Jack
Dyson Customer Service
Aug 11, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Jul 07, 2011 | Whirlpool Dehumidifiers
Hi, we've been given an innotek SSB-300 anti-bark collar and have no instructions! lights flash when we push the button, but we can't figure out what they mean! whats on or off!!! please help! ...
I have one and I know that if push the blk circle button and it is green it is on. Then to turn it off you hold the same button until it turns yellow and then yellow and red and that turns it off.
Jul 05, 2011 | Computers & Internet
How can i turn on my zen
The reset button cap on the lower left side of the unit may be jammed, causing the reset switch it activates to be come stuck.
This will put the unit into a loop in which it continually restarts.
You'll never see any sign of life if this occurs.
Be sure you see the "RESET" stencil or that may not be the reset button.
I've seen people poke paper clips their devices' microphone or speaker openings!
Be very careful when pushing the reset so that the button cap goes straight down.
If yours is stuck, unstick it, then it should come on if the battery is charged.
Then be sure to give it a FULL charge before using it, because while the button was stuck, power was being consumed.
Be sure to remove the rubber boot / skin before trying to reset the unit.
Jun 28, 2009 | Creative Labs Creative Technology Zen MP3...
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Delphi SKYFi3 XM Radio Receiver Logo
107 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
