Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
I had problems with my linksey wireless router. I had to redo the router connection and now i get wireless not in range using my laptop even if i'm using the lapto in the same room. Before i had problems i was connecting to a no secure router. Is there something i need to do to other than setup the router? thanks, Derril
    Genius:
  • 1,970 Answers
Mcdevito75 here, The router signal depends on the 4 sattelites that have to be in range for it to connect to the internet, shut down your computer or just restart your computer. If this doesn"t work un--plug router from the computer itself for 20 seconds and plug in again.
Posted on Jul 16, 2010
Having problems with wireless connection to printer. Should I reset router, if so how?
Hi Are you using Windows?
Did you manually create the connections to the printer or use supplied software?
Do you have admin access to the router?
If the router has been configured correctly, just switch it off wait 10 secs then switch it back on to reset it.
Nov 15, 2014 | Cisco Linksys WirelessG WRT54GL Broadband...
Don't have security to key to access wirelss on laptop
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 26, 2010 | Linksys WRT160N Wireless Router
I have a wireless connection from main pc to laptop but i cannot get it to connect wireless to laptop even though i could yesterday,it says in range one minute and then when i click connect it says out of...
Do you see any other wireless access points and if so are any of them are on the same wireless channel as your wireless router?
If so change your wireless router to a channel that the others are not using.
Apr 18, 2009 | IBM Computers & Internet
Router connections
Is your speedstream router also your high speed modem? If so, you will have to go into the settings on the Linksys and change its IP Address subnet from 192.168.1.1 to 192.168.2.1 (or you can use a different number than 2) You will then need to reboot both routers (and possibly the computers) and try again. The easiest way to get into the Linksys settings is to connect it directly to the laptop via network cable, then type in 192.168.1.1 in the web browser. No user name and admin is default password. (Make sure you change that, and the name of the wireless, and the security settings)
Good Luck!
Dec 08, 2008 | Computers & Internet
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Belkin w/range extenter question
you can use as many as you want, since they just find a signal and amplify it. using more than one shouldnt cause any problems
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless Connection
It's possible that you are not yet connected to the wireless network that you have at home.
May I know the model no. of your wireless router from Linksys?
What is the operating system of your laptop?
You might also want to check if your computer is picking up the signal braodcasted by the linksys router.
May 19, 2008 | Linkskey Computers & Internet
My laptop cant find my wireless connection but finds other connections in range.I can only connect using ethernet cable from router.spoke to sky who said I need to contact acer as my laptop is not...
you might be blocked your SSID broadcast in your wireless router make it broadcat enabled then it will find your connection.
Your lap is ok and settings are well, b.coz it gets other signales. So just check your wireless AP settings.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
