Just won't even print a test page.
I had another printer hooked up to my labtop, then I installed this one, made sure the port was the same, reset the printer but it doesn't print. The error just reads error printing. I don't know what's wrong. Am I suppose to install a driver? I do not have a cd or anything to add this new printer.
  • damonk Apr 21, 2008
    Canon bjc 4400
    Great, thank you. So I downloaded the new driver, but on the download it doesn't give me the option to select USB only LPT's or coms, so I selected lpt1 and changed that on my properties in the control panel, then restarted the computer. Now it says its printing and there is no error message but it did not print at all and didn't send the data to the printer. Do you have any other suggestions? Thanks again.
    Genius:
  • 3,587 Answers
Yeppers...what's the printer model/make?
Posted on Apr 21, 2008
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
How do I hook up my Acer Aspire laptop to my Epson printer?
You can hook up Acer Aspire to your Epson Printer Using the USB Port if the printer supports the USB port A type. I am not sure what model of Epson printer you are using. You may have to configure the printer either by going into add remove hardware and scanning for hardware changes and installing the Printer, or may have to put the Driver CD provided to you by the driver manufacturing company and install the driver which will also allow you to print a test page at the end of installation to give you a clear picture that the installation was successfull. Please ensure that the printer is connected to the laptop and is powered on while giving for a test print. Good Luck.
Feb 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cant get my vista labtop to print through router
Did you share the printer PSC 1410 in the XP Desktop computer??
Thanks
Riz
Jan 14, 2009 | HP PSC 1410v All-in-One Printer
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
Laserwriter 12/640 PS
hello the printer paper pick-up rollers are bad. this why you caanotuse the pick tray. the solution now is to set the printer to default and clear allstuff off memory. read the instruction below: LaserWriter 12/640 PS: IBM PC or Compatible Troubleshooting This article explains IBM PC or Compatible Troubleshooting. A message on the screen says the printer can't print. If you get such a message, try the following steps. Make sure that the printer is turned on. Check the network or parallel cables. Make sure that the PostScript printer driver has been installed. Nothing is printed; no paper comes out of the printer. If you don't get any response from the printer when you try to print a document, try the following steps: Check the Installed Printers list to see that your printer is selected. Try printing the document again, but choose Download PostScript Error Handling in the Printer Setup PostScript Options dialog box. Check the Paper Out light. If it is on, add paper and replace the paper cassette. If it is blinking, make sure the paper cassette is securely in place. Check for a paper jam. Check the printer cables. Check the position of the port communication switch. The port may have been turned off or the Interpreter settings may not be correct. Reset the communications settings to their factory default values by setting the communication switch to the Reset (out) position. Turn the printer off and back on again. Set the communication switch to the Normal (in) position. Turn the printer off and back on. Check the startup page. Reinstall the printer driver. For Windows 95 users, check the following additional item: Open the Printer folder, select the printer, and click Properties. click the PostScript tab and click the Advanced button. Make sure that ASCII data and "Send CTRL+D after job" are selected. For Windows 3.1 users, check the following additional item: Open the Printer Control panel, select the printer, and choose Setup. Select the PostScript tab in the Properties dialog box. Make sure that Protocol Options is set to Default if using the parallel port, or None if printing via NetWare. Sometimes Printing the First Page Takes Longer than I Expect The LaserWriter 12/640 PS automatically goes into an energy-saving mode after it's been idle for a while. When you print while it's in this mode, the printer takes about a minute to warm up before it can print the first page. The printer is properly connected and configured, but printing is garbled or displays unwanted characters. Check the communication switch and make sure that the Interpreter is set to the correct value. If you are printing a PostScript document, the Interpreter mode should be PostScript or AutoSelect.
Aug 08, 2007 | Apple LaserWriter 12/640 PS Plus Printer
123 people viewed this question
k24674
jasbo
jasbo
