Question about Kodak EasyShare C330 Digital Camera
How to correctly install new memory card
When I insert new memory card it says memory is full - how can I start using the new memory card
    Problem Solver:
  • 6 Answers
You need to set the camera to use the card and not the internal memeory
Posted on Jul 16, 2010
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
Camera keeps saying memory full but have inserted new sdhc card
The S1030 works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
My memory is full after 5 pictures and I have a brand new sd card in it.
This sounds like your camera is only using internal memory, and not using the SD card you are using. First check to make sure that the card is inserted correctly, also verify that it is the correct type of card by looking at your old card.
If you can respond with the make and model of the camera, I can give more specific instructions on what to try.
Good Luck!
John Vickers
Sep 18, 2011 | Cameras
Installed new memory it started fine then crashed no video now no beeps upon start up
Such errors of NO VIDEO mean:
- Memory not inserted correctly: pls remove and insert memory again
- Graphics cards possibly moved a bit while you were trying to install the memory: Remove graphics card and insert again.
Another reason could be: Graphics card is brurnt! Perhaps due to touching the chipset with hands full of static electric.
If above 2 suggestions do not work, put your graphics card in another PC and check if it works, if not -bad luck- replace it.
Aug 04, 2011 | Dell PowerEdge 1400...
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 | Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
C142 kODAK DIGITAL CAMERA. ADVISING INTERNAL MEMORY IS FULL. I HAVE PURCHASED A NEW MEMORY DISK BUT STILL GETTINGTHE SAME MESSAGE AND WILL NOT ALLOW ME TO TAKE PICTURES.
The internal memory is not the same as the memory card memory. The camera needs some elbowroom in the internal memory to work at all. It can't use the card memory while the internal memory is full. You need to delete some pictures from the internal memory, then insert the memory card, and it should work (assuming it is formatted correctly and is otherwise compatible).
Dec 20, 2010 | Cameras
Kodak easyshare c613: memory card says its full when there is no pix on it, what happens is: i turn it on, says "memory card full", i go to review, says "no pictures or videos to display on memory card",...
If you connected the camera to the computer with a USB cord to download your pics and then just yanked out the cord without using the "safely remove hardware" icon at the bottom right corner of your screen, the card may have been corrupted. Replace it.
Nov 10, 2009 | Kodak EasyShare C613 Digital Camera
My camera will not accept the memory card
Hello, one thing you might want to try is to format the memory card. To do this:
-Insert the card into your computer in the correct slot
-Wait until the computer displays found new hardware/device is ready to use
-Open my computer and look for the card(usually given a drive letter of H,I,J...) On most machines, it will be under a category heading of devices with removable storage
-Right click and select format
-Normally the default settings will work fine
-Select ok/format/continue
Hope this helps
-Chris
May 01, 2009 | Kodak ZD710 Digital Camera
INSTALLING A NEW MEMORY CARD
Ram open the tower with power off you shuld have 2 or 4 slots for memory add your new one then reboot
Jan 25, 2009 | HP Compaq Presario SR1420nx...
Kodak EasyShare C330 Digital Camera Logo
186 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
