Question about Compaq Armada E500 Notebook
My computer does not work. When I plug in the adapter, the two lights turn on but the it doesn't work.
  • 162 Answers
Hi
I am sorry that the Computer is not turning ON.
Please remove the Battery and connect the Computer to Direct AC Outlet and also remove and reinstall the RAM modules.
If the same issue persists then the available option would be replacing the internal Hardware component such as Motherboard.
Posted on Jul 16, 2010
Computer doesn't turn on. Tried just using AC plug in with no battery but doesn't turn on. When the AC Adapter is plug in there is a orange light on when battery is in and a white light with
If you are still having trouble I would take it to a local pc technician. I have had good luck an UniComputers on 23rd st but its not cheap...
Sep 30, 2012 | HP Pavilion g4-1117dx Notebook
When i plug the charger in the orange battery light comes on and the computer turns off
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Sep 29, 2012 | Toshiba Satellite P200D-11R Laptop AC...
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
The laptop doesn't start but the charger works.
Take out the battery and connect the charger.
Then try to turn on the computer.
If it works, there is no problem with your computer.
After that insert the battery, plug in your adapter and try turning on once more.
If it doesn't work, you need to get a new battery.
Oct 01, 2011 | Toshiba Satellite Pro L300 Notebook
Dell D810 Laptop wont power on. Have brought 2 new ac power adapters. They work (led light on power adaper goes on), but when I plug them into the computer the led light on the adapters go off. Computer...
HELLO FRIEND, THE PROBLEM WITH THE LAPTOP IS QUIT A MINOR ISSUE BUT YOU HAVE TO DO SOME SOLDERING WORK ON THE COMPUTER. THERE'S A POWER SUNG ON THE COMPUTER WHICH HAS TO BE SOLVED BEFORE IT CAN WORK WELL, AND STOP THE LIGHT OFF PROBLEM.
Jul 30, 2011 | Dell Latitude D810 Notebook
Sylvania Netbook SYNE T07526-Serial #7128230710064387. Bought less than a year. Stopped turning on.
When you said it's not turning does it have any indication of power and just doesn't boot to your operating system or It doesn't have any sign of power at all?
If it doesn't have power, try to remove the battery plug it into the power outlet using the ac adapter and turn it on. Check the adapter to see if it has a light to make sure that the computer is receiving power.
If the computer turns on but you can't get to windows see if any error message is displayed and be ready with your windows cd/dvd because a reinstallation might be needed.
May 23, 2011 | Sylvania G-Netbook
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
My xbox a adapter is plugged in but it isnt
if it isn`t lighting up then please try the adapter with some other computer and if it still doesn`t light up then it`s faulty.you need a new one.
Jul 12, 2009 | Microsoft Wireless Network Adapter Xbox...
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Compaq Armada E500 Notebook Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
