Question about Apple Wireless Keyboard
Accidentally left one battery in an Apple wireless keyboard. It is stuck / corroded. Any ideas on how to remove it safely?
  • Apple Master
  • 4,806 Answers
You'll have to pry it out gently with a flat headed screwdriver. Be very carefull not to break the contacts as you will need to clean the contacts after you have got the battery out of the keyboard.
Fine sandpaper will clean the contacts if you wrap the paper around a small flat headed screwdriver.
Regards.
Posted on Jul 16, 2010
LEFT SHIFT KEY NOT WORKING
If this is a wireless keyboard, you can do two things to try to correct this issue. You can remove the batteries and leave it sit for a few minutes and try again, or you can replace the batteries and see it that helps.
Mar 19, 2014 | Acer Computers & Internet
How to remove and replace batteries
    • 1 Flip your wireless mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
    • 2 Carefully remove each battery.
    • 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
    • 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Apr 13, 2012 | Apple (M5769)
Last battery in my Mac wireless keyboard is stuck inside. Second time this has happened. First time I took it to the mac store and the guy took it to the back room and got it out. When I asked how they did...
Usually a stuck battery is caused by a battery that has leaked acid in the battery compartment...If it a small space you might try a small dental mirror to see why it is stuck..
Since it is a keyboard a strong magnet like a mechanic uses might have enough force to pull it out...unfortunately some product are designed to be a pain in the backside so you have to resort to beating the xxxx out of it
Sep 18, 2017 | Apple Wireless Keyboard
Last battery is stuck in wireless keyboard casing
I am not an expert but I did fix this. First I drilled a small hole in the end of a battery. Second I used a long screw, any self tapping will work. Screwed into the battery a bit. Then pulled the screw with a pair of pliers. Out came the battery. Then, I cleaned out the battery compartment with a rotary tool attachment.
Feb 09, 2010 | Apple Wireless Keyboard
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard no power
Try scraping at the positive battery terminals.  Worked for me.
Jan 25, 2009 | Apple Wireless Keyboard
Apple Wireless Keyboard Logo
465 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
