Question about Craftsman Convertible 25cc. Gas Line Trimmer
Ho do the fule lines hook up to the carbrator
Ho do the flue lines hook up to the carburetor
    President:
  • Craftsman Master
  • 1,545 Answers
How do the fuel lines hook up to the carburetor, huh? Well...it's not too complicated. Small diameter line coming out of fuel tank goes directly to the carb on the fuel pump end..(end opposite the one with hole in the cover). The larger line coming out of the fuel tank goes to the longer nipple on the purge/primer bulb. The other line coming off of the carburetor (on the end with the hole in the cover) goes to the shorter nipple on the purge/primer bulb. The purge bulb "pulls" air and old fuel out of the carb thus allowing fresh fuel to flow in from the fuel tank and then it "pushes" this mixture of air/old fuel back to the fuel tank.
Posted on Jul 18, 2010
Why tiller won't crank
-You mean it can start for couple second if you spray starter fluid in to it...?
If so the fule line is clogged.
Good luck
Mai
Jun 15, 2014 | MTD PRODUCTS INC yardman"" garden tiller"
Starts with spraying gas into the carb then quits
You have spark, so problem with fuel. Maybe old gas. Determine if getting fuel to carburetor - if so you need to clean carburetor. If not, clean fuel lines or replace fuel pump.
Dec 28, 2013 | McCulloch Garden
Generator will not run. Can start generator by spraying gas directly in to carburetor but will not idle/continue to run. Not currently connected to load. Trying to prepare for hurricane season. Can...
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
Aug 14, 2010 | Honeywell HW5500E Portable Generator Not...
I have a 1996 gpz 1100 and the fuel tank was taken off for repair. My buddy pulled the hoses off along with the tank and doesn't remember where they went. I know one is the main fuel feed the other is a...
There are 3 hose, Fuel outlet tank vent and tap vac. The vent hose usualy goes down past the swing arm and is open to the world. the fule outlet suppies flue to the carbies and the vac tap one come from a vac port/s on the top of 1 or 2 carbies. and the other end goes tot he back of the fuel tap to turn it on.
Jun 28, 2010 | 1996 kawasaki GPZ 1100
I installed a new carburator but will not speed up
There were a lot of these years made and the wrecking yard is full of them for extra parts. As far and the carb.it may have been worn out or set around so long that things have frozen up inside. This will requirr you to buy a carb kit and the auto parts store. Shouldn't be but 15 or twenty bucks. But be fore you do that check the fuel filter. Some carburetors have one built in too. It would be right where the fuel line connects to it. The other filter is in the gas line either near the carburetor or under the vehicle running along the driver side door or there abouts. You can take it off when you fand it and blow through the end that is pointed away from te carburetor. Have a paper towel handle so you can blow the excess gas into the towel and check for dirt and gunk. If a lot came out the replace the filter. If it looked pretty good then replace the filter back on the truck because I doubt it is the problem. May I ask why you replaced the carburetor in the first place? The trouble may lie somewhere other then the carburetors. Raz
Apr 18, 2010 | 1988 Mazda B2200
I HAVE A POULAN 2300AV WOODSMAN CHAIN SAW I ONLY HAVE ONE FULE LINE IT BRITTLE AND BROKE DOES THE LINE GO FROM THE CARBURETOR TO THE FULE FILTER?
If no primer bulb it is like the video.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
HTH
Lou
Dec 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
When i prime the bulb try to start it will run for abot 2 seconds and will not run.you pull and pull and it will not start.we have cleaned the carb and gas lines.the saw is just one year old.i bought it at...
Inspect your hose routing. it should be similar to this:
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed. HTH
Lou
Nov 12, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My 1991 subaru legacy will not idle when its cold . it is getting progressively worse , now it wont idle at all .
Your ideler controler is sticky or going bad ! ( IT is like that flapy plate on the carbrator on the older modles). A good dose of fule injector will do the job most of the time.SO happy spraing and let me know how it went.
Nov 09, 2009 | 1991 Subaru Legacy
It wont start.
If it was stored with ethanol fuel on board your hoses may have holes or cracks as well. Inspect them carefully. It sounds as if there is a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH
Lou
Oct 24, 2009 | Husqvarna Chain Saw 20" Bar
Gettin an EE2 error - replaced the fule filter at the tank, removed and cleaned the sump screen, no luck. Does the sump screen on this stove fit into the sump with the open aspect of the screen facing the...
The open end goes toward the back of the heater.
Next try cleaning the flue.
Other potential causes for an EE2 are malfunctions of the circuit board, flame sensor or or fuel pump.
-Helping Hands Services
Fairbanks, Alaska
Oct 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
Craftsman Convertible 25cc. Gas Line Trimmer Logo
413 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
